building ramps- Mtbr.com
Results 1 to 11 of 11
Thread: building ramps
    building ramps
    So I've read many of the threads about ramp building and I think i am going to try to build one soon. I'm about to put cabinets up in the garage and tear down all the old shelves, which consists of a bunch of 2x4's. Most of the posts I've read said to use 2x6's. Do you think 2x4's will hold up.. or should I put more of cross beams (ribs) into it to support the ramp deck.
    Quote Originally Posted by RockTheGeek
    with a sturdy design 2x4's should be plenty, its bed time
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    i never use 2x6's on my ramps........ they are too heavy to carry......
    arrange your 2x'4 perpendicular to the ramp surface using the same center to center distance and they will be stiffer......
    style, flow...RIDE!!
    Looks like WCH's pic says it all; seems like 2x4s seems to be the way too go, WCH's looks like it is pretty light and sturdy.
    Scratchy Rat Racing
    "It's not that I'm lazy, it's that I just don't care."--Office Space
    When in doubt, whip it out. -Gee Atherton.
    Reputation: Coldfire's Avatar
    But how can you fix it to the ground?
    BTW is it an old pic? Coz your Foes ZigZag is black
    Coldfire
    LIVE FREE
    BE BRAVE
    RIDE HARD
    Pro Crastinator
    Quote Originally Posted by Coldfire
    .............BTW is it an old pic? Coz your Foes ZigZag is black............
    yup, last summer.....
    Quote Originally Posted by .WestCoastHucker.
    ..... using the same center to center distance and they will be stiffer......
    cool.. thanks.. I understand whats going on in the pic but what do u mean by using same center to center distance or what is center to center refering to?
    Pro Crastinator
    center to center = center (of 2x4) to center (of 2x4)
    space them the same distance apart, just orient them perpendicular instead of flat...
    gotcha... thanks a bunch.. hopefully i get to tear downt he garage sometime soon...
    Coldfire
    Usually unless you are putting on something slick like flat dead grass you can usually dig it into the ground pretty well. Or you could probably prop it against something since ( I dont know about you) I usually put it somewhere where I'm trying to jump over something and is pretty solid.
    Scratchy Rat Racing
    Pro Crastinator
    Quote Originally Posted by DH'er16
    it only moves if you try to stop on it......
    we never had a problem on any surfaces(grass, hardpack, concrete or asphalt)
  1. Plans of building a light weight FLUX?
    By roy harley in forum Turner
    Last Post: 10-22-2004, 08:45 AM
  2. Upcoming Trail Building Clinics
    By Paul B in forum Arizona
    Last Post: 09-04-2004, 08:10 AM
  3. Frame building class at UBI. Anyone?
    By dirtpaws in forum Frame Building
    Last Post: 07-07-2004, 02:16 PM
  4. Anybody building locally?
    By I_8_It_up in forum Washington
    Last Post: 04-16-2004, 09:20 PM
  5. Where to find on-line trail building documentation
    By DiRt DeViL in forum Trail Building and Advocacy
    Last Post: 02-14-2004, 09:04 AM
