brake noise on P2- Mtbr.com
Results 1 to 7 of 7
    Generation X freerider
    Reputation: cdog117's Avatar
    brake noise on P2
    i just got my p2 yesterday ,but i took off the front wheel to put it in the car and then i put it back on and it makes a loud hissing noise, its rubbing agianst the pads, i called my LBS and they said to take a flathead and try to wedge the pistons into place or something and it still does the noise. i no that it rubs a little before you break it in but this is loud. By the way its has a 8" Hayes MX2 on the front
    Former Noob Herder
    Reputation: zedro's Avatar
    either your wheel isnt installed properly, or the caliper is out of alignment.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Moce the inside pad in. losten the calaper bolts. press the brake tighten the bolds. let off the break and moe the inside pad out a bit.
    can you say that in english please
    ok what
    step 1. there is a knob on the right side of the break turn it to move the bad in about 1/16 to 1/8 of an inch
    2.press the front break
    3. the bolts on the fron brake itself take them and loosen them
    4.keep pressing the fron break lever then retighten thoes bolts
    5. turn the know from step 1 so the pad moves back out
    Former Noob Herder
    Quote Originally Posted by themontashu
    you're hired...
    (i really wish mods could give custom titles to people like on Ridemonkey....)
    Yo Paseo El Scream
    Reputation: BansheeHucker's Avatar
    Dec 2004
    the simple way
    i had the same problem on mine, just loosen the bolts that hold the disk on to the 8 inch adapter, move it around and tighten it were it doesn't rub
    Banshee Bikes
    Honorary Member Of The 200 Club
    Sponsers
    SixSixOne
    Soul Cycles
    Kenda Tires
    Quote Originally Posted by BJ-
    ..."if i can jump it on my feet whilst running as fast as i can, then it aint worth jumping on a bike"...
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  3. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  4. Disc Brake Noise -- Rotor Rubbing
    By carl spackler in forum Brake Time
    Last Post: 09-30-2004, 01:13 PM
  5. squeaking noise from Truvativ Boxguide on P2
    By tgreathead in forum Downhill - Freeride
    Last Post: 09-22-2004, 01:11 AM
