brake installation- Mtbr.com
    brake installation
    Does anyone know of a webpage that has step by step instructions on installing disc brakes. If anyone could post a link it would be greatly appreciated.
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Disc brake calipers varies grealty from model to model. Check out the manufacturer's website they usually have PDFs. Otherwise if you tell us the make and model some people might be able to help you from experience but there isn't one set of guidelines that applies to all disc brakes.
    Ok, thanks. I havent bought anything yet but im headin over to the lbs tommorow.
    There's no app for this.
    Reputation: JimC.'s Avatar
    get your LBS
    to "face" the tabs on your fork and bike frame. should cost about $10. Makes a perfectly flat surface for mounting and helps stop brake alignment problems. Jim
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Need help on cantilever brake pads installation
    By pcheninhk in forum Brake Time
    Last Post: 01-12-2005, 10:53 AM
  3. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  4. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  5. Marzocchi and disk brake installation
    By dcbeards in forum Downhill - Freeride
    Last Post: 06-19-2004, 12:34 PM
