Blackspire Stinger for 1 X 9?- Mtbr.com
Results 1 to 17 of 17
    ARC Driver
    Reputation: pbbullpup's Avatar
    I'm thinking about getting a Blackspire Stinger chainguide for a 1 X 9 setup. Has anyone used this?
    Meh.
    Reputation: XSL_WiLL's Avatar
    The chain will still be able to come off the ring on the top.
    Fort Valley = Gnarl Fest
    Reputation: Jekyll_Jockey's Avatar
    Quote Originally Posted by pbbullpup
    My bro has use an E-13 DRS and a front der, with the limit screws adjusted to keep the chain on the ring, as a makeshift single speed guide.
    "It sucks because that's what Boxxers of that generation were good at." -- XSL_WiLL
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    The stinger is designed for 2x9 setups, so the roller can move to the inside when you shift to the little ring. I don't think it would work, but I've never tried it on a 1x9 application so I can't 100% confirm.
    Ocala Mountain Bike Association - www.omba.org
    Oh, So Interesting!
    Reputation: davec113's Avatar
    It's meant for 2x9 w/ fd. So no, I wouldn't use it for 1x9. But you could use a fd as a top chainguide and get a single roller if you need something cheap and ghetto.
    ARC Driver
    Quote Originally Posted by davec113
    What kind of single roller would you suggest? I'm building a bike to ride on some DH trails that don't have chairlifts so it's like an hour ride up each time. I'm more concerned about something simple to keep the weight low.
    Could the stinger be modified to fit a single ring?
    Feb 2006
    It's the rubber roller itself that is "stepped" that allows the chain to shift up and down properly. If you replaced that roller with a single ring roller with no steps then it would probably work.
    ready to ride
    Reputation: ridefreeride's Avatar
    you may as weel just buy a guide dedicated to a single ring and not risk it
    N* = <3 <3]
    Meh.
    Quote Originally Posted by Jim311
    Even if the roller is replaced, it would still allow the chain to come off at the top of the ring.
    ARC Driver
    Quote Originally Posted by ridefreeride
    fair enough. can someone suggest something simple and light
    Meh.
    Any e13 guide.
    ready to ride
    or an mrp g2
    N* = <3 <3]
    Nov 2008
    Gamut P20 200grams with the bash ring. Simple, light, effective.
    Nov 2008
    check ebay for e-13 sts deals right now. I just picked one up for $74 and there are many more. They're older models, but hey, they're $74. just make sure you get the right chainring size/bolt pattern.
    Feb 2006
    Yeah, my front derailler keeps my chain on up top.
    What about an MRP 1.x? 60grams, very simple, just a top part. Would that work?
    I'm getting one for trail/AM use with a 1x9 setup.
    Swedish trail/AM/Enduro/DH-rider - Currently rides Spitfire V2 & Devinci Wilson SL. Spending the summer 2013 in Whistler, BC.
    I used a stinger with a FD in a pinch...3 days of lift access trails i dropped a chain once. it was way more efficient than i thought
