Big Ring Bash Guard?- Mtbr.com
Results 1 to 18 of 18
    Fat Skis/Fat Tires
    Reputation: rangerbait's Avatar
    Are there any other options out there besides this one?
    Capricious youth...
    Reputation: Prettym1k3's Avatar
    How many teeth are you looking to use? 42? 44?
    If you're using 36, 38 or 40, use a Gamut P40 bash.
    Meh.
    Fat Skis/Fat Tires
    Quote Originally Posted by Prettym1k3
    I'm looking for a ring that will protect a 44t.
    Currently my big ring looks like the kid on imjps's avatar, and I don't want that to happen again when I replace my crankset in the near future.
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    Instead of a ring, this is probably what you need:
    http://www.mrpbike.com/product.php?s...oduct&item=xcg
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    I have no idea who makes it but I have this thing called a "Rock Ring" sitting around in my garage.
    Northstar 2008 Riding Crew
    Fat Skis/Fat Tires
    Quote Originally Posted by Cable0guy
    Well, I'm already planning to run this 3-ring guide,
    so a full ring seems to make the most sense...
    Commit or eat sh!t
    Quote Originally Posted by e-bo-b
    You can run both the MRP guard and the Heim guide. Also, if you run 3 rings, you can't use a bashguard ring. You need to take the outer chain ring off.
    Fat Skis/Fat Tires
    So I just bought this thing for $18 on Ebay. It's 110mm and covers a 44t ring. I'm planning to run it with the Heim 3-ring guide. Anyone have opinions or experience with a similar configuration?
    Fat Skis/Fat Tires
    Quote Originally Posted by Raptordude
    Didn't see your response until just now...is it 110mm?
    Reputation: Mr. Blonde's Avatar
    It's for a 44t SINGLE ring. If you are using the outside of the spider you're gonna have to by or make spacers to get the bash away from the chainring and cut a HUGE chunk out of the bash to clear the crankarm. After all that the bash ring is going to be sticking out so far it will piss you off constantly.
    N* Bomber Crew
    I think so. Its a 5 hole spider so...I guess?
    Fat Skis/Fat Tires
    So, is there a solution for 3 rings, with a bash guard?
    N* Bomber Crew
    I think my Rock Ring thing works with 3 rings but you might have to search for the right size crank bolts since the larger spider hole will be used for the bash, large ring, and middle ring.
    Rides like wrecking ball
    Reputation: Bulldog's Avatar
    QBP (aka Quality Bike Parts catalog at your LBS) Tooth Fairy ring allows you to run a full triple crank plus the bash guard. I used it before I realized I never used my big ring and switched to oversized doubles (24-26 granny / 36-38 middle + bash). While I used it the Tooth Fairy was flawless.
    Quote Originally Posted by Hesh to Steel
    With people liking mongoose and trek bikes now, what's next in this crazy world? People disliking the bottlerocket?!
    salsa makes a bash ring that goes on that outside of a triple. also carried in QBP
    The best solution IMO is the MRP quarter bash dealio someone already showed you.
    i know race face made one a few years back. it was just called the big ring bash.
    the e-13 one u got is goood. ive had the best expirences. im running a cut one on my V10 right now
    Takw/agranofsalt
    Jan 2005
    probably an old-school Girvin?
