best way to remove stripped allen head screw in my Super T- Mtbr.com
Results 1 to 9 of 9
    Reputation: freeriderB's Avatar
    New question here. best way to remove stripped allen head screw in my Super T
    yeah it's a stupid question, but I need to get this screw out of my Super T so I can change the oil.
    It's on the top crown, and it is actually too tight because when I took the top cap off, I could not slide the cartridge or coils out (so it's crimping the fork leg). Either it worked itself in tighter, or the LBS over torqued it when swapping the coils months ago.
    Anyway...any ideas?
    I can take it to the LBS and have them heat it with a torch, but I would like to get it out an easier way.
    Thanks.
    I love RIDING!!
    Dec 2004
    I would go to (Canadian Tire if your a Canadia) or what ever store you have were you live that sells car tools then buy a set of special allen wrenchs (I don't know the name) that are all specially made to fit in striped bolts, screws ect..
    i should be working
    Reputation: rpl3000's Avatar
    sometimes you can pound an oversized torx in the allenl hole to get them, otherwise its drill and easy out. take it back to the LBS if you think they over torqued it. at the very worst you'll get charged a few $ to have it removed.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    use a dremel to grind a slot in the bolt head then use a flat screwdriver.....
    great ideas
    much appreciated.....
    Quote Originally Posted by .WestCoastHucker.
    Reputation: MTBSully's Avatar
    Sep 2004
    thats a good idea. Also, u might want to try using some vice grips and just putting it around the screw. (Unless the screw is below the metal surface)
    Sully
    Drill the head off, then use a reverse drill bit.
    another vote for the dremmel tool cut a slot and use a flat head screwdriver i've had to do it numerous times over the yrs works like a charm .
    Kill that $hit!
    Reputation: MorphineAddict's Avatar
    Quote Originally Posted by AKRida
    Yep, me too. Although one thing to watch out for is a really soft metal screw.
  1. Help! Stripped head on thomson stem bolt
    By sodade in forum Tooltime
    Last Post: 05-09-2005, 09:18 AM
  2. Help.. stripped screw on XTR shifters
    By Francine in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2005, 07:38 AM
  3. Stripped allen head bolt?
    By squirrellyrabbit in forum Tooltime
    Last Post: 05-06-2004, 10:38 PM
  4. striped cleat bold in my shoe!!...now what??
    By KamikazeBikr in forum General Discussion
    Last Post: 01-19-2004, 01:06 AM
