BB question- Mtbr.com
Results 1 to 11 of 11
Thread: BB question
    BB question
    hi guys
    my current BB is 73mm, im going to get a frame with an 83mm BB width and my BB is a truvativ howitzer so could i just get a new axle or would i need a new bottom bracket?
    i do not believe the axles are available separately. atleast not on qbp
    Glad to Be Alive
    you can't buy a new axle ....you will need a new bottom bracket....most likely you will need new cranks too ....get the Saints
    Reputation: Pedal Shop's Avatar
    if you want a good consumer source for looking up parts available out there --
    try www.bti-usa.com it's a wholesale company so you won't be able to buy from them but you can at least check on what shops are able to buy.
    ride global, buy local
    Pedalshop.com also on Facebook
    Marin - Transition - Santa Cruz - Cove...
    Mountain Dew enthusiest
    Reputation: alex55's Avatar
    Most 68 and 73mm bottom brackets and cranks that I know of are interchangeable between those sizes. once you step up to a 83mm, the crank spindle and bottom bracket sleeve wont be long enough even if you remove any spacers, etc.
    wishes Iowa had mountains
    '11 Transition Bottlerocket frankenbuild
    '09 Origin-8 Interrogator frankenbuild
    '80 Rumme
    Mar 2005
    Wow, 1/2 the responses had no thought what so ever put in to them! The axle is not available seperately. You will need to buy the 83mm BB. It is too bad they don't offer just the axle.
    new cranks? another month without the bike
    Quote Originally Posted by AmirBernard
    hi guys
    You should also tell us what crank/bb interface you currently have. Is the bb spindle attached to your cranks or are the crank arms (both or them) seperate from the bb?
    bike rider
    Reputation: Lelandjt's Avatar
    You WON'T need new cranks if you can find an 83mm ISIS BB that is long enough to work with Howitzer cranks (other companies ISIS BBs have internal bearings). I'm not seeing one on Truvativ's site so you'll have to do a little searching to see if someone else makes one. If not, you have to buy a new style 83mm external BB and 2 piece crank.
    Keep the Country country.
    bike rider
    Quote Originally Posted by DHRracer
    Howitzer is Truvativ's ISIS setup with external bearings.
    Dec 2008
