Barspins on DH bikes.- Mtbr.com
Results 1 to 42 of 42
    Reputation: mornish's Avatar
    Hi everybody!
    I know that there have been many threads already about barspins, but I haven't found any that really answer my questions. So, I was wondering: If I bought this would I be able to put it on my bike and then that would take care of both the front and back brake cables? Also, what would I have to do with the shifter cables? Just make them really long and unwind them after each spin?
    Miles
    Fort Valley = Gnarl Fest
    Reputation: KomodoRider's Avatar
    my mind just got blown! but what about the front brake? and you do still have a rear der. cable to worry about
    DH bikes are not made to do bar spins, thoes are called DJ/Park bikes
    OMG GUISE IT HAZ A AIER SHOCK WTF OO DUZ THAT?!?!?
    bike rider
    Reputation: Lelandjt's Avatar
    That will take care of your rear brake hose and your front hose can be routed through an oversize BMX star nut. Your shift cables will still be a problem. This product seems ideal for a singlespeed FS park bike that sees enough DH use to require hydro brakes. Not a lot of those.
    Quote Originally Posted by Lelandjt
    Would long shifter cables be work-able?
    I'm assuming that those couldn't also be routed through a big star nut?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Routing a shifter cable through the star nut wouldn't do anything... Do you know what a star-nut is?
    If you ran long lines, you can do spins. When I ran a front brake and a rear derailleur, I didn't route the hose through the star nut. I just left my hoses and cables long enough to wrap around twice.
    The star nuts are the ones in the headset right?
    Is there much friction with the brake cables there or do they wrap around easily enough without the brakes in the way?
    Check out Atomlab's Hydro Twist http://www.atomlab.com/brakehydro.html It looks like the same style product as you found but a little cleaner lookin.
    Bikes Rule
    Reputation: Demo-9's Avatar
    Mar 2006
    Pinkbike called.... They want their thread back...
    Quote Originally Posted by Adidad
    That ones also less expensive.
    BrassBalled DropbarNinja
    Reputation: mrpercussive's Avatar
    kinda hard with the stanchions getting in the way.... hmmmmmmmm
    Meh.
    Quote Originally Posted by mrpercussive
    Single crowns. Hmmmmmmmmmmmmmm.
    Reputation: prophet413's Avatar
    gonna go grab some popcorn for the "real dh bikes don't have single crown forks" fight thats about to happen
    rider
    run a 1x9 and rig the shifter to the top tube
    Cam McCaul uses a hydro splitter/gyro. He mounts a shimano bar end road bike shifter to the water bottle mounts on his frame so that he has 9 gears (no front shifter). Basically, set your gear before you drop in.
    Or alt: just run a really long cable like BMXers do. Will allow you 2 bar spins if you set it up right. Learn to spin both ways and you can bar spin as much as you want.
    Be aware, a DH fork and front wheel has a lot more mass to get moving intially and therefore a lot more momentum once it is moving, so this will make things harder.
    No i can't do a barspin, nor do i want to, just some info.
    Nothing good here.
    SuperInstigator
    Reputation: tibug's Avatar
    Real downhill bikes don't have single crown forks.
    I wish I didn't know now what I didn't know then.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Quote Originally Posted by tibug
    Real downhill bikes like Chris Kovarik and Amiel Cavalier ride?
    That may have been true 5 years ago, but depending on the course and setup there are definitely a few "real" DH bikes with single crown forks. It's quite common in Australia for instance.
    NOAH SEARS
    MRP - VP of Business Development
    Pivot Cycles - Team Rider
    My arm hurts a little
    Reputation: #1ORBUST's Avatar
    There you go. With a long rear break and shifter cable. Simple.
    Hardtail downhill
    https://youtu.be/sXhWDoz7_CM
    Quote Originally Posted by SHIVER ME TIMBERS
    tresspassing, thievery and poaching is all part of a DH'ers life
    Reputation: cummings's Avatar
    May 2005
    probly just get long cables. i dont know how good of a rider you are, so I'm not gunna judge, but are you talking about a slopestyle bike? then maybe. but a dh bike, get long cables if your set on bar twirls, a hydro gyro would be whack. Im also guessing it would hinder your braking performance as well.
    22Pride
    Meh.
    Quote Originally Posted by cummings
    I wouldn't think that it would hinder performance. It's just a reservoir of fluid and some seals. It doesn't change the ratio or anything.
    Reputation: Luigiugueto's Avatar
    Oct 2007
    Can't see why, i'm guessing you just need to add a bit more brake fluid, seal those banjos with sealing tape a bit and you're set.
    Still finding figuring out how the mechanism works but yeah, awesome idea.
    Speaking of single crowns, how does the marzocchi 66 RC3 compare to the 888? The 888 can have 20 mm more travel and looks like it would be stronger, but are there any other big differences? (Any reason not to get the single crown versus the double? The single has enough travel for me.)
    Also, what's a 1x6?
    Mornish, You did read the disclamer at the top that says, their product id for dirtbikers only. Just thought I would point that out so you dont spend some dime and figure out it doesnt work for DH bikes.
    Quote Originally Posted by redmonster89
    I did not see that, but the atomlab one doesn't have one, I might ask them about that.
    Thanks for all the help everybody, I've got what I needed to know.
    SuperInstigator
    Dirt Bike=mountain bike in Deutsch
    GUIDANCE COUNSELOR
    Pretty sure euros mean mountain bikers when they say "dirt bikers".....
    NOAH SEARS
    Oct 2007
    And you happen to ride your DH bike on water?
    lame jokes aside, As long as you have a SC fork I think it's all good
    Quote Originally Posted by Luigiugueto
    Okay awesome.
    I'll see what happens whenever I end up getting a Blindside. Hopefully eventually
    Oct 2007
    Quote Originally Posted by mornish
    Okay awesome.
    You're looking to get up a Blindside with a SC, and you're looking to pop barspins?
    I think that's not the frame for you dude, but that's just me.
    I might not get the blindside, maybe the bottlerocket instead. I'm still fine with my bike though so it wouldn't be for a while, my opinion of what bike I'd like might change.
    Oh ok. Thanks for enlightening me.
    I can ride a two-wheeler
    Reputation: thomasmunka63@hotmail.com's Avatar
    get a dual crown fork ...way easier to do barspins on those; the way they are designed and the way they alter your geometry makes them ideal for dirtjumping
    just get a hacksaw, cut down the sanctions and springs, thread some new holes for the topcaps, get rid of the top crown and you're set
    ....a fox 40 is ideal for doing this mod
    Quote Originally Posted by [email protected]
    That's amazing.
    pro
    pro is offline
    Oct 2007
    That's amazing.
    That sure is amazing.
    An amazing idea! You'd be throwin bars like theres no tomorrow!
    Quote Originally Posted by pro
    Oh yeah, definitely.
    ... my fork actually has 5 crowns, it helps so much, the bars spin like cake.
    RIDE DIRT
    Reputation: dh_drew's Avatar
    I've never spun cake... Is it easier to spin than bars?
    Quote Originally Posted by Demo-9
    Pinkbike called... They want their question back.
    Quote Originally Posted by dh_drew
    Oh of course, it's just like pizza but with sugar.
    1st of all, I would love to see some dirt bike bar spins.
    2nd of all, Tibugs's remark about DC vs SC was a joke.
    Reputation: buckoW's Avatar
    Feb 2007
    In German a "Dirt Bike" is a dirt jumping hard tail.
    The hydraulic gyro is only necessary if you are into doing multiple tailwhips and barspins in the same line. Normally when on a DH bike you get the opportunity to do either not very often. Therefore; a front brake bled through the steerer tube like this
    adn the rear der. cable and brake housing long enough to do one to two full rotations like this
    Good luck and the BMX style star nuts kink your hydraulic housing. Make your own.
    Is this guy going to be riding down rock gardens whilst doing double bar spins and tail whips?
    Quote Originally Posted by hugeben
    that's why i mentioned doing the fox 40 mod
    Mi vida es bueno
    Reputation: splatman's Avatar
    Quote Originally Posted by Rover Nickl
    (first part of vid)
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/F4qXoA9TJwE&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/F4qXoA9TJwE&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    D-G
    D-G is offline
    Nov 2008
    The proper setup to do barspins and tailwhips is to sell your mountain bike and go buy a BMX. Leave the mountain bike for the mountains, and go get your gay on with a BMX.
