banshee ?'s + post morphine pics- Mtbr.com
Results 1 to 6 of 6
    Reputation: anti-spandex's Avatar
    will the morphine dropouts take standard qr?
    (basically im cheap and want to run my current wheelset til i destroy it)
    can i run a 113mm BB or do i have to get a 118mm BB?
    (again being cheap cause im stripping parts from my old HT)
    i would like to see some builds if any of you guys ride the morphine.
    thanks.
    Reputation: MorphineFreak's Avatar
    yes you can use qr, just wouldn't recomend it with the horizontal drop-outs. I don't know about the BB, I run Diabolus cranks. Here are some pics of my set-up
    Quote Originally Posted by MorphineFreak
    thanks.
    my real ? is: will the axle that banshee incl. with the frame fit a q/r hub?
    if it helps my rear hub is a crappy shimano stock disc hub that came on my kona.
    is that a junior t or super t on your morph?
    what size frame? just wanted an idea of size built with a dc but im pretty sure i gotta go 14" cause im short.
    looks alot like the setup i want but i want to go with a longer single crown fork to save a bit of weight and keep my turning radius, plus 6" is enough travel for me.
    Doesnt ride Banshees
    Reputation: Banshee Rider's Avatar
    Here are a couple pics of my morphine and how i had it set up at different times before i sold it. It was a nice bike, my recommendation is to run a 2.5 tire no matter what, the ride in the woods with a small tire is totally different, shitty to say the least. Just run a bigger tire and its a killer do it all hardtail. As for the axel question, the one that comes from banshee is for shimano hubs, so if you have one (which i think you said you did) then your all set. Have fun, its a nice ride.
    Reputation: LandonVega's Avatar
    hows that e13 setup workin out for you? I just ordered one and it should be in probaly a week from now.
    signature
    I don't know about the hub for sure, I never have really messed with rear qrs,but I think it should. It's a jr.t and the frame size is a small. And the e.13 rocks big time, had to do a little work because of the diabolus bb cups, but is well worth it.
  1. walt works? (post pics if you have them please)
    By appleSSeed in forum 29er Bikes
    Last Post: 09-14-2004, 07:29 PM
  2. Freeride/downhill bike Banshee Morphine vs. Iron Horse SGS Pro
    By ucsbwsr in forum Downhill - Freeride
    Last Post: 07-16-2004, 08:46 AM
  3. Is this where we post pics that aren't good enough for Pission?
    By Finch Platte in forum California - Norcal
    Last Post: 04-08-2004, 11:34 AM
  4. What components recommended for Banshee Morphine?
    By Suicide by Bicycling in forum Downhill - Freeride
    Last Post: 04-07-2004, 07:17 PM
  5. Banshee Morphine 18" pictures?
    By Cloxxki in forum Downhill - Freeride
    Last Post: 02-02-2004, 01:37 AM
