axles?- Mtbr.com
Results 1 to 8 of 8
Thread: axles?
    thats not to steep is it?
    Reputation: thatdownhillkid's Avatar
    axles?
    is it possible to change the axles from a quick release 14mm to a bolt 14mm thru on the back wheel? i cant stand my quick release. it keeps coming loose and my wheel has fallen off because of it. so would i be able to change the axles?
    07' fsr xc pro
    06' bighit2
    05 hardrock comp set up as a dj bike
    02 fat boy hemi
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    holy crap, that probably wasnt fun to deal with midrun, i am pretty sure you can, 14mm is the same size as 14mm, right
    HARDTAIL PRIDE- 09 Kona Five-0
    Reputation: Jettj45's Avatar
    No 14mm is waaay different than 14mm.
    Meh.
    Reputation: XSL_WiLL's Avatar
    What bike are you using that uses a 14mm? That's BMX sized...
    If it's a sealed cartridge bearing hub, it will depend on the availability of a bolt-on axle. Not all hubs can be converted.
    Glad to Be Alive
    get a bmx axle
    Meh.
    SMT... you can't plug a BMX axle in everything...
    1. the thread pitch might be different
    2. if the hub is a sealed cartridge bearing unit, the axle has flats for the bearing races to sit on. This is specific to the hub.
    nvrmnd
    i think its 12mm.
    its my old bighit wheel that i got at whistler. im moving it over to my new single speed 2006 p.2 cr-mo. ive got it spaced out correctly right now. dead straight chain line. and its sitting fairly far into the drop outs. but cant put a chain tug on a quick release right?
    07' fsr xc pro
    06' bighit2
    02 fat boy hemi
    Meh.
    I think you mean 10mm... There are not any 12mm QRs that I'm aware of. If it's the Bighit or the p2, it's definitely 10mm.
    Surly makes a chain tug for the QR.
