Avid X.O/Juicy - Parts- Mtbr.com
Results 1 to 3 of 3
    My arm hurts a little
    Reputation: #1ORBUST's Avatar
    New question here. Avid X.O/Juicy - Parts
    Are there any online shops that sell X.o/Juicy Carbon replacement parts???
    Bro has problems!!!
    1. Lever Pin fell out of his front brake (Juicy Carbons) 1st run at Whistler almost crashed. (He's running looped housing as a replacement)
    2. Snapped a bunch of set bolts off his X.o derailleur along with a bunch of little c-clips.
    He has called SRAM tech. they told him to f-off. He's contacted 3 LBS and they can't do anything.
    I thought the x.o stuff was rebuild-able, where are the parts???
    Thanks,
    Hardtail downhill
    https://youtu.be/sXhWDoz7_CM
    Quote Originally Posted by SHIVER ME TIMBERS
    tresspassing, thievery and poaching is all part of a DH'ers life
    Is flexy
    Reputation: njhcx4xlife's Avatar
    SRAM won't help you... but your LBS is retarted. Tell them you want QBP part number #DP5979 which is the X.0 bolt kit. You can most likely get the circlips at a good hardware store. It may or may not have what he needs but here is the pic too. As for the lever blade I'll see what I can find.
    Good People... www.efingersports.com
    Is flexy
    http://www.bti-usa.com/public/catego...?page=1#AV5020
    That will fix the brakes. More stuff than you need but I can't find the pin sold seperately.
    Hope that helps.
