Avid Juicy pad replacment- Mtbr.com
Results 1 to 3 of 3
    Does any one knows how to replace pads in the Hydr Avid Juicy 7 brakes.
    The description in their site does not match the brakes.
    Reputation: string's Avatar
    Push the pads together and pull out. It is usually easier to pull one pad at a time once you push them together.
    There is a little metal keeper that sits at the top of the pads and caliper that you sometimes have to pop out seperately. You can push it out from the top with a small screw driver from the top of the caliper if it does not come out with the pads.
    Thanks, I will try it.
  1. Replies: 23
    Last Post: 05-27-2005, 08:50 PM
  2. What's causing my pad wear?
    By BigLarry in forum Brake Time
    Last Post: 04-05-2005, 03:23 PM
  3. Splined rotors... Shimano vs. Avid... Compatability?
    By MidshipmanX in forum Brake Time
    Last Post: 02-03-2005, 10:54 AM
  4. Some thoughts on pads for Avid Juicys
    By tscheezy in forum Brake Time
    Last Post: 09-30-2004, 01:04 AM
