Avid Juicy ?- Mtbr.com
Results 1 to 7 of 7
Thread: Avid Juicy ?
    Now rollin the Big Hit
    Reputation: J-mizzle's Avatar
    Avid Juicy ?
    Here's the deal my brother just got new rear Avid Juicy 5 and before even getting it on the bike pulled the red tab out that seperates the pads, and squeezed the lever. Now the pads are too close to the rotor to get the brake on. I am unfamiliar with hydraulic brakes and was wondering how to reset the calipers to the original position so they can be setup.
    Any response would be appreciated.
    Peace-----
    J-Mizzle
    Hailing from Reno, NV by way of Vegas...
    Now rockin the Big Hit!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Dec 2004
    OH MY GOD YOU DIDNT REALLY DO THAT DID YOU?!?!?!?!?!
    just kiddin, its no big deal it happens all the time, all you need to do is get a very thin flat-head screwdriver and very slowly and carefully so as not to damage the pads pry them apart. this will hurt nothing as long as you dont gouge the pads....so i say again, go slowly and carefully!
    good luck
    Glad to Be Alive
    Quote Originally Posted by vwmtnbiker
    good luck
    that is the way...wider screwdrivers work better...If you have the plastic spacer that comes with Hayes(don't know if you got it with that set of Avids) then by all means use that instead of a screwdriver
    Just Ride
    Reputation: zerossix's Avatar
    may wanna hit the screw driver head with some rubbing alcohol or clean streak. depending on how nasty your screw drivers are. definlty dont do it with a screw driver you just used to clean your derailleur pulleys.
    Uhhhhh...
    Reputation: TheSherpa's Avatar
    Quote Originally Posted by zerossix
    Good idea.
    -TS
    Fayetteville, AR and N.W.A RePrEsEnT
    Card Carrying Member
    Reputation: kitchenware's Avatar
    If you have to tell someone that, that's doing this job, they shouldn't be messing with it.
    Yo Paseo El Scream
    Reputation: BansheeHucker's Avatar
    Dec 2004
    do what they have been telling you, but be sure to clean the pads after with alchohol, just in case
    Banshee Bikes
    Honorary Member Of The 200 Club
    Sponsers
    SixSixOne
    Soul Cycles
    Kenda Tires
    Quote Originally Posted by BJ-
    ..."if i can jump it on my feet whilst running as fast as i can, then it aint worth jumping on a bike"...
  1. Sram9.0 to Avid Juicy 5 switch
    By TheNewOriginal in forum SRAM
    Last Post: 12-07-2004, 08:14 AM
  2. Avid Juicy 7 n00b questions.
    By martynda in forum Brake Time
    Last Post: 09-22-2004, 07:52 AM
  3. Avid Juicy and Centerlock Rotors
    By arnobarno in forum Brake Time
    Last Post: 06-25-2004, 04:47 PM
  4. Avid Mech / Juicy adapter & rotor compatibility?
    By El Kabong in forum Brake Time
    Last Post: 05-28-2004, 09:01 AM
  5. Avid Juicy 7 203mm disc availability ?
    By JerryBoneJr in forum Brake Time
    Last Post: 05-06-2004, 10:41 AM
