Anyone running short cage derailleur's? Question....- Mtbr.com
Results 1 to 16 of 16
    Kill that $hit!
    Reputation: MorphineAddict's Avatar
    Right now I have an XT drivetrain (9 sp in the rear), but I'm thinking about using an Ultegra shortcage (9 sp) in the rear instead for more rock clearance. Does anyone know if this will be compatable w/ my current setup? I.e. would I need different shifers or cassette? Thanks.
    EDIT: Okay, I saw another post on this and I realized I had left out some importaint info. I'm only running one chainring up front. (38) w/ an MRP chainguide system. Maybe that's relavant info, maybe it's not, but I figured I'd add that. I'm still curious about the actual shifters working with that deralleur though. Thanks again......
    May 2005
    Quote Originally Posted by MorphineAddict
    hey dude,
    i've been running an ultegra short cage (road) derailer on my dh bike for years. it works awesome, shorter cage for better clearance, stiffer spring for snappier shifts and way cheap.
    you want to run a different cassette though. pick up a nice road cassette or speed cassette(smaller gear ratio's) and it will shift cleaner than your mtn cassette(wider range of gear ratio's). you won't have those small gears though for climbing if it's a freeride bike. but for pure DH, i've found it to be a sick setup.
    basically a road de-railer works better with a road cassette. your 9 speed shifter will work fine with a 9 speed road derailer and 9 speed cassette and I currently run a SRAM Trigger shifter with the same ratio as the shimano.
    P"
    A friend used an Ultegra derailleur and it snapped off after a drop. Not sure why, but it did. Maybe they aren't built as beefy as mtn derailleurs?
    pay me
    May 2005
    Quote Originally Posted by MD Bullit
    hm... it snapped after a drop? did he bash something hard(a rock maybe) on the landing? b/c any de-railer will snap. but i'm betting that the chain was too short and he took to many links out.
    if the chain is too short and the suspension goes through it's travel it will put too much load on the chain and snap will go the derailer. i seriously have ruined less short cages (road) derailers than the standard mtn or short cage mtn's.
    P"
    Quote Originally Posted by Phil Winn
    P"
    No, his chain was the correct length. He had bottomed the bike out before with no bad results. I haven't had any problems with XTR mid cage derailleurs so it's all good.
    pay me
    Kill that $hit!
    hey dude,
    P"
    Right on, thanks. That answered a lot of questions for me. One more though.... will it still work okay w/ my mtb cassette until I can get a road cassette? Or will it be skipping some gears?
    the derailleur jockey pulleys may rub the teeth on the bigger gears (30-34) on a MTN cassette. So, wait until you get a road cassette to use the road derailleur.
    pay me
    Kill that $hit!
    makes sence... Thanks!
    [email protected] NYC Freerider
    Reputation: Master_Jako's Avatar
    hehe...look what a little stick did to my XT...Sh!t happens ...I was also wondering if short cage will be compatable with my current 9sp setup...
    Kill that $hit!
    Quote Originally Posted by Master_Jako
    Hey Jako, did you notice any change in your shifting smoothness when you put on that pully thing-a-ma-jigger? I've always wondered about those.
    May 2005
    you should be okay if you tune it properly but you'll have a few gears (2-3) on the upper or lower that doesn't feel as smooth. i would wait though to run the road cassette with the road de-railer if you really want to feel the benefits.
    ps.. i actually don't run the ultegra.. too spendy. i buy the shimano 105(2 gear). there like 30 bucks on performancebikes.com
    P"
    May 2005
    he's absolutely correct.
    P"
    the reason i bought it is becuase i had a huge loop that got snagged on brush and stuff...this completely cut it down to size...the shifting deff got smoother...well worth the $8...called an Avid Rollamagic
    Kill that $hit!
    P"
    I actually found an "almost new / barely used" ultegra for $30. That's why I was having all these questions. I'm gunna pick it up tonight after work. It's a hell of a deal.
    Reputation: OneBlueJoker's Avatar
    I had one of those avid thingies i didnt notice any difference at all.. It shifted the same without one of them so hope that helps!
    eci
    Reputation: snowskilz's Avatar
    i use a med cage xt with a ultegra 11-27 road cassette. It feels frikin awesome. Snappier, faster etc... I would def suggest it. and it def doesnt hang down as far as a long cage so it doesnt get caught on tons o stuff
  1. short cage derailleur and bullit
    By captainpolution in forum Downhill - Freeride
    Last Post: 04-05-2005, 08:17 PM
  2. Question about running larger front tire
    By dsully575 in forum Wheels and Tires
    Last Post: 02-08-2005, 03:08 PM
  3. short cage rear der w 11x32 cassette
    By FUD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-07-2004, 02:35 PM
  4. XO long cage vs. short
    By Treybiker in forum SRAM
    Last Post: 07-28-2004, 10:56 PM
  5. Drivetrain question those running Top Swing/22 tooth drives, most of you I assume...
    By Gnarlygig in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-23-2004, 03:38 PM
