Air Sprung!?- Mtbr.com
Results 1 to 7 of 7
Thread: Air Sprung!?
    Reputation: Reamer's Avatar
    Air Sprung!?
    Does an air type shock/fork setup work for heavier guys too? I was looking at the Iron Horse 7.9, and the versus blitz II with same rear shock and fork, and the transition bottle rocket with the same shock/fork setup. Just curious if it performs as good as a coil sprung suspension for the heavy dawgs too?
    Jun 2005
    not so good reviews thus far,, and alot of stuck down shocks that had to be sent back..
    Quote Originally Posted by fiddy_ryder
    Interesting, thanks for the info.
    Aug 2005
    idk... how heavy??
    if i were over 145...150 id go for the coil..?
    i mean... if ur racing it might matter a little with the weight and all... but id go with the coil if i were u... less to worry about.. and itll only add like... 2-3 lbs at most...
    Jun 2005
    Quote Originally Posted by Reamer
    check the review section here at mtbr....
    Meh.
    Reputation: XSL_WiLL's Avatar
    DHX Air has it's problems, some people have had good luck with them. No mid-stroke support with the DHX-A shocks. But air spring technology has come a long way.
    Fun-O-Meter
    I'm 200 lbs....
    ...and I run a DHX-Air rear and a Marzocchi 66 SL up front. No problems so far! And I love the tunability of air shocks.
