Air preasure for DH & Freeride- Mtbr.com
Results 1 to 11 of 11
    I'm using Fox DHX for my RMX and i'm 185lb. What is the air preasure for DH racing & what for freeride?
    surf-ride-repeat
    Reputation: pdirt's Avatar
    Quote Originally Posted by kruz
    The less pressure you can run without continually pinging the rim from lack of air....
    but it depends mostly on conditions and the coarse.
    If it is a grippy coarse, more air pressure, the more you can run the faster you roll on sprint sections ,etc...
    If it is slippery from wet...
    I like to run low pressure in the front , semi low in the back.
    It is dusty and blown out...my least favorite...
    piss on it , drink beer in the shade at the dirtjumps...
    Glad to Be Alive
    Quote Originally Posted by pdirt
    For racing I would say these are the rules but add 5 to 10 pounds more....i give up grip to roll faster
    Beyond the stars
    Reputation: RedDwarf's Avatar
    Um guys, what I think the guy is asking . . .
    is what air pressure he should use in his shock not what air pressure he should use in his tires . . .
    He gives his weight and shock type, but doesn't mention anything about tires, so I'm guessing he wants to know SHOCK air pressure . . .
    Reputation: freerider167's Avatar
    Dec 2004
    check the manuel?
    Quote Originally Posted by DJBiker
    You're right. The manual only show 75-175psi. I need my shock performance to be plush & smooth. So what's the right preasure?
    Dec 2004
    try 120- 140 for your weight maybe even more cause i put about 70% of what i weight in my 5th element.
    Former Noob Herder
    Reputation: zedro's Avatar
    never go down to the minimum 75psi, keep it above 90psi. Too low and you risk messing up the shock, and the valving doesnt work properly either.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Quote Originally Posted by freerider167
    Thanks guys.
    Beyond the stars
    Is that true for all shocks . . .
    Quote Originally Posted by zedro
    or just the DHX?
    what about the Swinger 4-way?
    Former Noob Herder
    or just the DHX?
    depens on the shock of course, always read the manual
  1. new 05 stink, ?'s on how forks work
    By cobra in forum Shocks and Suspension
    Last Post: 04-22-2005, 11:20 AM
