Advantages of a direct mount stem?- Mtbr.com
Results 1 to 5 of 5
    May 2005
    I'm in the process of getting a new bike and can't seem to decide if I want to go direct mount or not. I've heard about how a direct mount can sometimes twist stanchions or break, but at the same time I want the lower height they offer. So what's everybody's opinion on them? For reference, this will be going on an El Cuervo with a 888.
    Reputation: mace2's Avatar
    go for the direct-mount... it's super low profile and i rode it for 2 years with no problems whatsoever (the 888 one)
    as long as it's clamping onto the steerer, and not just bolted through the crown, i don't see why you'd have any more trouble than a normal stem
    Glad to Be Alive
    I have run a direct mount for 4 years with no problems......a lower mount helps with body positioning and helps keep your center gravity lower....better for DH.....I would do it
    May 2005
    Cool, I'll go with that then. Thanks for the help!
    Glad to Be Alive
    Quote Originally Posted by BridgerSkier
    when you buy your fork it should come with it
