20mm Thru Axel?- Mtbr.com
Results 1 to 14 of 14
Thread: 20mm Thru Axel?
    Reputation: RuNDmC1087's Avatar
    Sep 2004
    20mm Thru Axel?
    Just wondering, is it really a large improvement over the regular Qr? Anyhow Thanks
    Drugstore Trailrider
    Reputation: papajohn's Avatar
    Quote Originally Posted by RuNDmC1087
    Yes.
    John W.
    Body Armor--Don't Leave Home Without It!
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Two factors.
    Quote Originally Posted by papajohn
    Yes.
    John W.
    First, the 20mm interface is much beefier in several ways because of size, contact area, and bolts (usually). Secondly, most of the forks that come with 20mm axles are usually built stronger also. Some manufacturers do make almost identical forks with QR or 20mm, but most have some significant differences. There is definitely a more positive steering precision in rough terrain with 20mm front axles in just about all cases.
    Glad to Be Alive
    once you go 20 you won't feel "safe" with QR
    How about the new crop of forks? AM1, Shermans etc with QR and 150mm travel (and 32mm stanctions), do they compare for rigidity with prev gen ~130mm thru-axle forks?
    Reputation: sdtmtb's Avatar
    Quote Originally Posted by fsrxc
    Yes, even the new generation forks benefit from having a 20mm axle. A mate had the QR Nixons and said they were awesome...didnt need a thru axle, then he tried the 20mm and said he was wrong. This guy works for a bike comp wholesaler and rides alot of new stuff.
    SMT hit it when he said, once you've tried it you wont go back. I have 20mm set up on my trail bike as well as my DH.
    VIA
    VIA is offline
    Reputation: VIA's Avatar
    Doble that....
    I'd love to have 20mm in the back too...like thos DH-9
    Soul Cycles
    Jan 2005
    if i have QR and i buy a fork with 20 mm do i get a new wheel set or hub?
    VIA
    VIA is offline
    Quote Originally Posted by sreiman
    I think that you gonna be better off buying a new front wheel ...but if you like your rim you may get a 20mm hub for cheap and put it on that rim.. It may end up costing you more money...go for a new fron wheel.
    your mom
    Reputation: Ace_Jellyfish's Avatar
    Dec 2004
    ever since i've gotten a 20mm front i always look at the rear skewer and wonder why i havnt bought a frame with a solid 12mm rear axle
    No longer riding a haro!
    Does anybody know where I can buy a cheap front wheel (new) for around 100 bucks.
    It needs to fit a hexlock axle, because I want to get the stance flow!
    Craig
    Reputation: Chingy's Avatar
    my mate says the stance flow is crap. he works for a shop and ride a lot of new stuff. Get a 2nd hand tcpplus sherman or a Z1 stance flows have crap damping
    www.hope.co.uk
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    it depends, when you move to a dual-crown fork...it doesn't make as much difference IMO, especially when you put a BMX-bolt-on axle in your hub (if it can accept it). 20mm is nice, and for all downhill oriented stuff it makes sense to just make it all 20mm so it's all "standard", but for some applications it's not critical, a good solid bolt-on axle can make a big difference too.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    COOL BUZZ & TASTY S-TRACK
    Reputation: spacoli's Avatar
    Nutted axle hubs
    Quote Originally Posted by Jm.
    I have a P2 that came with both ends 10mm nutted axle (which I thought was good for jumping).
    I know the rear end has to be stronger, but I was wondering how the front was comparable to a 20mm thru axle in regards to flexing and steering inputs.
    I just upgraded the fork and stayed with a standard dropout.
    Hope it was a good choice.
    Can you buy cheap and or expensive front and rear aftermarket 10mm nutted axle hubs?
    I might want to have a lighter set of wheels built.
    Any info would be helpful.......thanks
    I can fix it............... my dad has an awesome set of tools
  1. reign 1 20mm or standard axel ?
    By b12yan88 in forum Giant
    Last Post: 10-22-2004, 09:25 PM
  2. 10mm bolt on axel
    By huskyamerica in forum Wheels and Tires
    Last Post: 08-30-2004, 02:17 PM
  3. Surly axel threads damaged?
    By MrXC in forum Singlespeed
    Last Post: 06-23-2004, 05:53 PM
  4. I am looking to trade my 2001 Z1 MCR 20mm with Hub
    By devilsfanforlife in forum Shocks and Suspension
    Last Post: 03-07-2004, 09:31 AM
  5. Manitou 20mm hub interface question?
    By BanzaiRider in forum Shocks and Suspension
    Last Post: 02-13-2004, 07:41 AM
