2011 Jedi fat man spring rate?- Mtbr.com
Results 1 to 18 of 18
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    What spring rate for a 200lb'er, 350 or 400?.. currently on 300x2.75 and way too soft
    Attached Thumbnails Attached Thumbnails 2011 Jedi fat man spring rate?-kimg2616.jpg
    '16 Balance
    '11 Jedi
    '08 Toyota FJ Cruiser / Facebook: NyNomadFJC
    Jun 2019
    I had a 2011 jedi, rode it with a 350. I weight 130lbs
    I'm riding the 2013 one with a 325.
    If my maths are ok, you'd need something around 500lbs spring.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    i ran a 500 at 210lbs. i also rode it rampage status. you would probably be fine with a 450...
    Feb 2006
    cool beans. thank you!
    '16 Balance
    '11 Jedi
    Glad to Be Alive
    Isn't that the wrong stroke for the spring....I think those were 3.0 strokes...you can go higher but not lower
    Jun 2019
    It's a 2011 jedi so 2.75 is the right size.
    They increased travel and shock size for the MY2014
    Feb 2006
    will the DVO Jade with 241x76 (9.5 x 3) fit ?
    '16 Balance
    '11 Jedi
    Jun 2019
    You can't fit a longer shock on a jedi.
    222*70 only. (or 222*63 but you'll have less travel)
    Feb 2006
    great
    '16 Balance
    '11 Jedi
    Feb 2006
    i might be looking at getting a Medium frame, would have change make any difference depending on the year?
    '16 Balance
    '11 Jedi
    Jun 2019
    Most recent jedis (after 2014) are longer by 10mm if I recall. (and they use a 240mm shock) between 2011 and 2013 there is not much difference, most visible one being the machined links.
    Feb 2006
    I'm looking at a 2018
    '16 Balance
    '11 Jedi
    Jun 2019
    2018 has more traval, 27" wheels, slacker head angle, more "linear" suspension, a tad lighter. I don't know what are the difference between 2014 and 2018.
    So it's more modern, but you'll be at home as it still work like a jedi, a bit better.
    Feb 2006
    I just have to do some geometry comparisons to see what I can swap over
    '16 Balance
    '11 Jedi
    Pro Crastinator
    wasn't the last production run of Jedi's in 2017?
    Feb 2006
    '16 Balance
    '11 Jedi
    Pro Crastinator
    Canfield only sold old stock in 2018...
    Feb 2006
    either way.. that's what i'm looking at. my small 2011 is one size too small
    '16 Balance
    '11 Jedi
  1. Balance or Jedi... Jedi or Balance..
    By shwinn8 in forum Canfield
    Last Post: 1 Week Ago, 11:32 AM
  2. Fox RP2 spring rate? I'd like to compare spring rates
    By jbourne84 in forum Shocks and Suspension
    Last Post: 02-02-2017, 11:45 AM
  3. Jedi on Jedi
    By jasonjm in forum Canfield
    Last Post: 05-27-2013, 05:42 PM
  4. Spring rate for Jedi
    By Rob-Bob in forum Canfield
    Last Post: 04-21-2011, 08:21 AM
  5. fat fat fatty fat fat fat
    By evilbeaver in forum Riding Passion
    Last Post: 12-10-2006, 01:23 PM
Members who have read this thread: 11
