2011 Fox Float 36 RC2 FIT 180mm travel adjustment (shim)- Mtbr.com
Results 1 to 3 of 3
    Anybody know of a service bulletin to specifically remove a shim from a 2011 Fox Float 36 FIT RC2 fork to remove a travel reducer shim (currently at 170mm) and go back to the original 180mm of travel. Any help would be appreciated. Can't locate it on Fox's tech center.
    http://www.foxracingshox.com/fox_tec...011/index.html
    Scroll down, click 36 & 40mm under the product selector, select your fork model. If you can't find the answer you're looking for... step away from the fork.
    Reputation: bullcrew's Avatar
    Jan 2005
    Quote Originally Posted by iafr8e
    I couldnt find the answer he was looking for lol....
    My Sponsor House
    "I dont make memories, I make History."
    CANFIELD - AVALANCHE SUSPENSION - SCHWALBE - TLD
