2005 Specialized Big Hit FSR VS. 2005 Giant Faith 2- Mtbr.com
Results 1 to 16 of 16
    Freeriding is a LIFESTYLE
    May 2005
    New question here. 2005 Specialized Big Hit FSR VS. 2005 Giant Faith 2
    Well i was trying to figure out what bike to go with Big Hit FSR or Faith 2 and i decided to go with the Big Hit FSR over the Faith 2, and now I'm starting to think I should have went with the Faith 2. I ride extreme freeride, what bike do you guys think i should have went with?
    Reputation: NorcoRider's Avatar
    Dec 2004
    Reply
    If you tell us why you don't like the bighit then maybe we can help u. I have a Faith 1 and I love it.
    Reputation: zocchi ryder's Avatar
    Mar 2005
    Quote Originally Posted by specialized_darby
    narf faith......narfaith......naaarf......faith
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    The faith is a great bike, the big advantage of the maestro system is that you get a solid rear triangle and much shorter linkage members, so it should make for a stiffer rear end, but the bighit is not "small" by any means. The maestro linkage system does what it claims, and is a real nice ride, but again, the bighit is a nice bike too. I would have let the geometry be the deciding factor, rather than the actual bikes, because they both perform very well.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    Mar 2005
    Quote Originally Posted by Jm.
    Actually..........The faith is nowhere near fully active under braking, and because of the "length" of the unified rear triangle there is more leverage against the small links and pivots. Drastically increasing rear flex.
    Mar 2005
    Quote Originally Posted by zocchi ryder
    sorry to sound blunt, both are good bikes.
    Uhhhhh...
    Reputation: TheSherpa's Avatar
    Wrong. Try again.
    Fayetteville, AR and N.W.A RePrEsEnT
    Mar 2005
    Quote Originally Posted by TheSherpa
    Wrong. Try again.
    My dad has the F1 and i have a big hit i can spend hours scrutinizing. Belive me. A fully active susp design will not let its caliper rotate around the rotor. The faith and the Vp-free are just a little better than a single pivot in this manor. both designs' calipers roll in towards the cock-pit during compresion. I may sound like a radical but it's true.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Faith is a URT?
    I think one of the things Sherpa was referring to was your comment about the Faith being a URT. I haven't even studied one very closely, but I'd find it hard to believe it's a URT. If it is, we've had a time warp.
    Mar 2005
    Quote Originally Posted by TNC
    I'm sorry if i somehow said anything about either being a URT! (wich they arn't)
    Mar 2005
    I meant the pivotless rear triangle. Not that the BB is part of the swingarm
    Uhhhhh...
    I was mostly just stating that it was not a URT. Also, FSR bikes have alot more brake interaction then you, or specialized would like to believe.
    Jm.
    Jm. is offline
    A fully active susp design will not let its caliper rotate around the rotor. .
    What are you talking about? The giant IS a fully active suspension design, but that has nothing to do with whether the caliper is going to rotate or not, what you are talking about is braking isolation, but fully active bikes are referencing the pivot location, wheelpath and interaction of chain forces, not braking forces.
    The wheelpath of the giant maestro lets it pedal very well and remain fully active. I've ridden them and I don't detect any noticable braking interaction. I am comparing to my current FSR bike, and I've ridden plenty of FSRs and single pivots in the past, so I can tell when it "stiffens up".
    Buckle Up
    Reputation: WheelieMan's Avatar
    Hmm, by looking at the bike it appears that the braking performance would be very similar to a single pivot. The Instant Center remains in "single pivot territory" throughout all of the travel.
    Dec 2004
    actually the faith stays quite active under braking. There a slight bit of brake jack but it is the best braking bike i have ever rode ( and i've ridden a vp-free ).
    yeah, but the faith is the uglest bike ever made, and they blatently stole the DW design. get a 7 instead
  1. question
    By sky84 in forum Riding Passion
    Last Post: 10-02-2010, 03:52 PM
  2. Replies: 11
    Last Post: 01-29-2008, 07:33 AM
  3. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
