2005 Boxxer upgrades? Are there any air kits/plusher things I could do??- Mtbr.com
Results 1 to 5 of 5
    Reputation: skamatt23's Avatar
    Apr 2005
    Back in the day I remember other shocks I owned had support from aftermarket manufacturers for air kits or "black box" type stuff for these forks.
    I am in desperate need of a red spring to help my preload problem but i am wondering if stepping up to a higher rake fork/more modern setup is a better idea. Shock just doesn't feel plush at all despite a recent rebuild from my LBS and in general I was wondering if this is as good as it gets. Just lots of spring noise hitting the lowers...crap like that.
    I believe these use stock 10wt Red Rum...are higher weights worth it?
    Reputation: blue109's Avatar
    Apr 2005
    I read through this...my springs are super long and newer Boxxers in the 2006+ years have single springs that are much smaller/supplemented with air.
    Not sure this will work with my setup.but thanks for posting. Looks like an uber plush offering!
    Quote Originally Posted by skamatt23
    I'm questioning the worthiness of this upgrade, but: http://www.risseracing.com/forks.shtml Look at the last item.
    Ricky DH
    Reputation: rep_1969's Avatar
    Information I posted on another thread:
    Here is the information from my buddy:
    Black Box:
    I purchased the upgrade direct from Rockshocks at the time because no one carried it. I would contact SRAM to get the purchase info on it. It’s still in their parts list so I’m guessing it’s still available.
    Install:
    http://www.sram.com/_media/techdocs/...BoxUpgrade.pdf
    NSMB info:
    http://www.nsmb.com/gear/boxxerblackbox_04_04.php
    Hope this information helps you.
