2000 Z1 Qr20- Mtbr.com
Thread: 2000 Z1 Qr20
    flat pedal rider
    Reputation: rallyfox's Avatar
    Idea! 2000 Z1 Qr20
    I have an older 2000 Mazoc Z1 QR20, anyone know if you can use the QR20 hub with any other thru-axle forks? I'll post a pic later we need some clarification.
    Intense for Life
    www.intensecycles.com
    www.the pedalsmith.com
    Reputation: Hardtails Are Better's Avatar
    May 2005
    It's just a standard 20mm through axle hub, so it'll work with any other 20mm fork. You just have to take the Marz. axle out, and use the one that came with the other fork.
    Feb 2006
    It depends on the vintage of the hub. The original QR20 axles were slightly under 20mm, as I found out a few years ago when broke my quick release. The new QR20 axle would not fit so I had to transfer the new QR into to old axle. A standard 20mm axle will not fit in my Y2K WTB QR20 hub; I've tried. But, at some point they changed the design to fit standard 20mm axles.
    May 2005
    Quote Originally Posted by Squidley Diddley
    Interesting. I've got an '01 Dirt Jumper 1. It's axle really is 20mm.
