160mm x 15mm hub???- Mtbr.com
Results 1 to 6 of 6
    Chillin the Most
    160mm x 15mm hub???
    I'm doing some research for my new bike for next year and one of the frames I'm considering uses a hub that's a 160mm width with a 15mm axle.
    I've been looking and the only hub I've come across is White Industries. Not many reviews on their hubs, so I'm kind of concerned. I've checked BTI and some websites, but have come up with nothing. I've also tried to contact the mfg, but haven't recieved any replies.
    Thanks.
    Former Noob Herder
    Reputation: zedro's Avatar
    sure its not 165x15? anyways, Hadley's standard sizes are 10-12-15mm axles with 135-150-165mm spacing (any combo), however they also make odd spacing sizes too. The thing to consider is how far the disk rotor mount needs to be vs. the dropout, and for that you should be asking the bike maker.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Chillin the Most
    Canfield...
    It's for a Canfield Formula1. And according to their website it's a 160mm hub. From what I've read it doesn't come with the hub only the axle and it doesn't give any options or suggestions. I've been trying to contact them, but have had no luck. Thanks.
    BTW - The Shiver is doing great. I might try a heavier oil (10wt), as my rebound is only running about 4 turns out from full slow so it may need a bit more damping control.
    Former Noob Herder
    hmm thats odd they wouldnt elaborate. The Super8 had a 160mm hub but that was with a 14mm axle.
    Maybe give a shout on Ridemonkey, think there are a few Canfield owners there
    Yeah, ask "Toshi" at ridemonkey. He has a F1 and knows the Canfield Bros.
    Here's a link to his thread on ridemonkey.com
    http://www.ridemonkey.com/forums/sho...24#post1253924
    Chillin the Most
    thanks..
    yeah I found it. Guess it's a Hadley, probably special for Canfield.
  1. DT Swiss 240S Disc rear hub durability
    By riverrat in forum Wheels and Tires
    Last Post: 09-28-2004, 03:12 PM
  2. Replies: 7
    Last Post: 05-08-2004, 08:32 AM
  3. Front disc -to- Fixie only hub
    By itsdoable in forum Singlespeed
    Last Post: 03-23-2004, 09:41 PM
  4. 24h rim with 32h hub? Leave every 4th hole out?
    By Duckman in forum Wheels and Tires
    Last Post: 03-10-2004, 09:53 PM
  5. Which hub should I buy?
    By stoom in forum Singlespeed
    Last Post: 02-27-2004, 02:18 PM
