12mm Through axle?- Mtbr.com
Results 1 to 17 of 17
    V-Shaped Rut
    Reputation: big_slacker's Avatar
    12mm Through axle?
    I finished converting my hope pro 2 rear to 12mm TA, but my question now is about the axle itself? Are the axles standard? I don't mean in terms of 135mm or 150mm, I mean can you just buy any old axle or are they hub specific? Different materials, is there Ti available? I'm a sucker for light + strong.
    Reputation: Mr. Blonde's Avatar
    What frame?
    biking is fun
    Reputation: climbingbubba's Avatar
    135mm or 150mm is important in this case. most 150mm frames have their own specific system so you need a specific rear axle.
    most 135mm frames you can use any generic 12mm rear axle (most, not all). My favorite is the hadley rear axle. really light and easy to use, haven't broken one yet. Haven't seen a Ti axle 12mm that is hollow so the hollow aluminum ones are way cheaper and lighter.
    Im not sure about your hub but I just replaced my rear axle 2 weeks ago (12x150) and I didnt require any sort of hub specific axle. I'm not sure if ti axles are available but the aluminum one I got (azonic recoil) was only 102 grams compared to the 220 grams the stock steel one on my bike was. Even if you cant find a ti axle the aluminum ones are still pretty damn light
    Reputation: daisycutter's Avatar
    Hadley makes great lite axles. There is a reason Intense uses them
    Quote Originally Posted by Norcoshore1
    ^ Ti is not lighter than aluminum.
    V-Shaped Rut
    135mm on an intense SS. So it sounds as if a hadley axle will work. Didn't even think about AL, I was thinking (having never seen one) that it was like a steel bolt on such as my SS roadie uses.
    Quote Originally Posted by Mr. Blonde
    I never said that it was
    I just used this Hadley on my 135mm 951 with Canfield wheels and it works great. It fits the dropouts perfectly and looks cool.
    http://www.universalcycles.com/shopp...1&category=401
    Working on my Drops
    Reputation: MTBAlex's Avatar
    Mar 2006
    Hey steve
    Post a pic of he finished SS. Can't wait to see what you done with it.
    Reputation: david8613's Avatar
    May 2005
    no body uses maxle anymore?
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    Quote Originally Posted by big_slacker
    SS owner here. The Hadley is a perfect fit. Do it.
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Maxles are the epitome of shitty axles
    Ground Steeze. @iggy_strbac
    NWS
    NWS is offline
    Jun 2010
    You mean for the same volume of material?
    Or, for the same shear strength if both are used to make a 12x150 axle?
    V-Shaped Rut
    Quote Originally Posted by MTBAlex
    Hey steve
    Will do, its not completely done yet but its getting there. Plenty of time before the snow melts up here.
    biking is fun
    im guessing you already bought it but just for reassurance sake I ran a 12mm hadley axle with a hope pro 2 hub on my intense SS so you should be golden
    In fact I think i even have an extra laying around somewhere....
    V-Shaped Rut
    Quote Originally Posted by climbingbubba
    Did not buy it yet, interested in selling your extra? PM me.
