104mm 38T ring with ramps/pins?- Mtbr.com
Results 1 to 8 of 8
    Anyone make a 38T middle ring in a 104mm 4 bolt pattern?
    I'd like to run like a 24/38 combo on a dual ring setup with a chainguide, but the best I can find so far is a 36T middle ring in that bolt pattern. The only other thing I could find was DH single rings with no ramps pins, which I'm guessing would not work well on a dual ring system.
    Thanks in advance
    Todd
    Truvativ makes a 38T pinned/ramp ring - its cheap. Bikeman sells them.
    I run 24 Shimano/38 Truvativ/40T max e13 Supercharger with SRAM 11-32 cassette on my all-purpose FS bike.
    Sep 2004
    probly raceface
    Chillin the Most
    Yep Truvativ...
    as syadasti pointed out Truvativ makes a 38t x 104 ramped/pinned ring for dual ring applications. Since your from Ute I would suggest giving Truvativ a call and ordering direct. Because Bikeman, great online shop BTW, is on the wrong coast it may take a bit longer to ship, if they even have it in stock.
    Xtremely Moderate
    Reputation: e<i>o's Avatar
    Quote Originally Posted by syadasti
    I've looking for a 38T also.
    The only 38T Truvativ ring I could find on Bikeman's site was the 4mm DH version.
    Maybe I'm blind.
    "Korash your enemiez, zee zem driven bevore you, and ear ze lamentation of za vemen"
    The Gnarchitect Sketch.
    Reputation: Archdukeferdinand's Avatar
    I've got an extra 4-bolt truvativ big ring, I'm pretty sure its 38T (have to dig it out and check) . I've never used it, it came right off for a bash guard. PM if you're interested, I'll let it go for cheap.
    Edit- actually, its a 44t, ramped an pinned. Came with a set of OEM '03 hussefelts I bought and says "trushift" on it. It has more scratches than I remembered too from sittingaround in the back of my jeep for a couple months, but its still in close to new condition.
    Quote Originally Posted by e<i>o
    Maybe I'm blind.
    I bought two from them - give them a call on the phone - special order items aren't listed...
    Chillin the Most
    Quote Originally Posted by e[i
    o]I've looking for a 38T also.
    Maybe I'm blind.
    You can also order direct from Truvativ, really it's not that hard. [/i]
  1. 38t big ring for 2*9 application?
    By TeXe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-16-2005, 11:42 PM
  2. 54 42 30 Xc Crankset ? ! ?
    By reisenhaure in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-05-2004, 05:50 PM
  3. chain binds up on smallest crank ring
    By ewarnerusa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2004, 09:23 PM
  4. Missing 4 teeth on big ring == problem?
    By phUnk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-20-2004, 06:28 PM
  5. correct size bash ring?
    By Redmon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-11-2004, 08:57 PM
