10 mm hub fit 12 mm frame?- Mtbr.com
    10 mm rear for coil air 2011
    Can I run a 10mm qr thru axle on the rear of a coil air 2011? Is there some sort of reducer to allow it to fit? Coilair has 12 mm thru axle
    what hub do you have?
    Hub is a banshee 135 mm 10mm thru axle
    BLAH BLAH
    Unless the hub is convertible to a 12mm or the frame has adapters (which I believe it doesn't) no.
    Whats this line for?
  1. Replies: 5
    Last Post: 03-10-2011, 08:25 AM
  2. Replies: 0
    Last Post: 08-17-2009, 09:01 PM
  3. Press Release: Newest CHUMBA Frame - VF2 Sub 6lb. Full-Suspension Frame Now Available
    By CHUMBAevo in forum Custom Builders & Other Manufacturers
    Last Post: 01-13-2009, 09:59 PM
  4. WaltWorks frame and fork? Frame&frame?
    By wadester in forum 29er Bikes
    Last Post: 09-07-2007, 07:33 PM
  5. Replies: 3
    Last Post: 12-11-2006, 09:24 AM
