1-ply tires with DH tubes or 2-ply tires with regular tubes?- Mtbr.com
Results 1 to 9 of 9
    New question here. 1-ply tires with DH tubes or 2-ply tires with regular tubes?
    I've got an '05 ASX on the way and I'm trying to figure out how to lighten up its trail riding characteristics a bit. Tires and tubes are the easiest way to do that (and the only thing I can afford to change after paying for the bike.)
    So, what sounds like the best way to lighten things up a bit while still handling dirt jumping and some mellower DH shuttle rides?
    Run 1-ply tires with DH tubes
    or
    Run 2-ply tires with regular tubes?
    Alternately, if both of those ideas are retarded, maybe I'll just run 2-ply tires with a DH tube in back and a regular tube in the front and just suck it up and pedal harder?
    I only weigh 150 and there aren't a lot of big drops where I ride, really. Biggest I go is 8 feet to good transition.
    Finally, here is a picture of someone's hawt black ASX that they posted in the bike porn thread.
    NOTE THAT THIS IS NOT MY BIKE, JUST A SEXY PICTURE!
    I wanna talk to Samson!
    Reputation: konabiker's Avatar
    Take advantage of the UST wheels that you have and go tubeless. That will save you a good 2 or so pounds in rotational weight. Check out Maxxis or Michilen for tires.
    JackNugz
    Quote Originally Posted by zedro
    no, but they are shinier....it's like the fututre, where everything is really really shiny.....but still really just the same ol'crap
    Quote Originally Posted by konabiker
    Dig my edit in bold. Sorry for the confusion.
    hands up who wants to die
    Reputation: rpet's Avatar
    Only you can answer the question.
    How it works for you depends on your own riding style, your speed, which tires and which trails you ride. How much tire pressure you want to run is a big issue here too. Are you 150 lbs or 250 lbs?
    I'd say go for a dual-ply tire in back, single in front and "regular" tubes. Carry a spare DH tube and put that in back if you flat out. It's an ongoing process...
    But this stuff is all super subjective.
    Every rider on this board can give you a different answer.
    -r
    Reputation: lebikerboy's Avatar
    Jan 2005
    I personally used to run dual-ply with Nokian DH tubes. Found the rotating weight was way too much. Now I run single ply Maxxix Minion F&R with the same 1.8mm Nokian tubes. I weigh 230 lbs and don't jump a lot but ride fast.
    Quote Originally Posted by rpet
    -r
    V10 Freerider
    Reputation: Frankenschwinn's Avatar
    Ghetto tubless
    The Super T you have is really a very good fork. I'd take that fork over a Fox 40 or a Boxer unless i was entering a fashon contest instead of a race
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    light tubes & heavy tires
    "Why are you willing to take so much & leave others in need...just because you can?"
    VIA
    VIA is offline
    Reputation: VIA's Avatar
    With 150lbs. 2ply and DH tubes and u'll never get a flat...
    Deal with the extra pound.. is no gonna kill u and is gonna make ur legs stronger..
    Blanco
    Quote Originally Posted by phUnk
    Take laxatives the night before you ride.
  1. question
    By sky84 in forum Riding Passion
    Last Post: 10-02-2010, 03:52 PM
  2. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  3. Mountain Bike Gear Ratio Calculator V4.0
    By FireDog46 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-29-2004, 11:57 AM
