08 Glory 0- Mtbr.com
Results 1 to 7 of 7
Thread: 08 Glory 0
    Reputation: dwnhlldav's Avatar
    Feb 2006
    08 Glory 0
    Not much call for them around here (Wisconsin), but we had a new one through the shop. I took it for an extended test ride and was totally blown away by how well it pedals. I think I need to get rid of my Bighit.
    Disclaimer: I fix bikes for a living.
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    Maestro is gud...
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    great
    HARDTAIL PRIDE- 09 Kona Five-0
    I wish I had...
    Reputation: iron1's Avatar
    The only thing I dislike about that bike is that it weighs a ton...literally.
    I wish I had...
    Reputation: craigstr's Avatar
    Sep 2003
    I've got a Lg. 08 Glory 0
    48 lbs!!! Could probably lose about 3-4 lbs if I went with UST tires and run stans strips. The stock Kendas and tubes weigh a ton.
    Quote Originally Posted by craigstr
    wont save you as much as you hope. anyway, best places to start losing weight are the cassette, seat/post, alu r axle, stans/tubeless. from there i'd look at changing the cranks to single ring and getting an lg1 or a similar taco design (gamut makes a really light guide too, i think it might actually be lighter). the wheels are heavy, but not as bad as i expected. i didnt drop nearly as much going to outlaws as i was hoping. better bet is hope II pro w/ mavc 721, not too expensive but will lose you alot.
    mines sitting at about 40 w/out brakes but has rotors. should sit around 41.5 w the formulas.
    the frame will take an air shock pretty well too. i like mine alot - its got a pretty light build, and another bike with the same build would probably sit closer to 38-40 range, but 41.5 isnt terrible by any means. they just come with burly setups so nothing will ever brake.
    May 2005
    my 08 glory 1 i have at 40 lbs. and it will be lighter once i go tubeless and get new cranks and a new chainguide. and also a different rear axle, the stock is a beast. the stock giant grips do not last long.
    WTB wheels
    minion 2.3 in the front and a chunder 2.3 in the back
    E13 chain guide
    boxxer team
    sunline bars, stem, and headset
    carbon seat
    thompson seatpost
    x9 der/shifter
    time pedals
