07 Specialized Demo 7 travel adjust?- Mtbr.com
Results 1 to 8 of 8
    I bought a used 07 Demo 7 and am not sure if the travel adjust spacer is internal or if the previous owner alreadt removed it ( If it was just a spacer that limited shaft travel by fitting Under the bottom out bumper.)
    please explain
    also what is the stock spring that comes on the demo 7 as it seems too soft, but I am not sure what it is so do not know what spring rate to try next?
    please help
    also please email me the answers as i can not seem to change my old email adress on MTBR
    email is [email protected]
    Oct 2007
    first, you dont have to make two threads with the same question.
    for your spring weight, quick forum search brought up this thread: http://forums.mtbr.com/showthread.ph...ht=demo+spring
    sounds like ur the same weight so should apply the same
    as for your travel adjust, id assume u can find the answer with another quick search if no one responds
    I already searched peaple mention it but do not say how
    Oct 2007
    http://cdn.specialized.com/OA_MEDIA/...o%20Manual.pdf
    "NOTE: Stock setting for the shock stroke is 2.375”, resulting in 7.3” of travel. Travel can be increased to 7.7” by removing the small travel limiting chip located under the bottom-out bumper on the shock shaft."
    Dec 2008
    Unwind your spring so you can get behind the bumper.
    Reputation: his dudeness's Avatar
    I know for a fact that this has been covered about a hundred times before as I have commented on these all before... You could have searched and found it easily.
    Remove the shock, unthread the coil from the body, the shock can be partially disassembled from there, take off the travel limiter chip that is attached to the shock shaft right behind the bottom out bumper, put the shock back together, re-install on the bike.
    Nov 2006
    You can remove the chip without removing the shock from the frame, it's U-shaped.
    Dec 2013
    Thx, about too !
