07' Specialized Big Hit Shock Mount Trick?- Mtbr.com
    Teh Original Dirt Muffin
    Is there a certain way to switch the setting from steep to slack easily on the big hit? My shock is about 2 mm too long and I am having trouble craming the mounting bolt in, do I have to do anything? Specialized manual didn't say jack about it.
    Thanks, Shredder111
    Oct 2007
    i would think if you compressed the shock, or let the air out, filling it back up later of course, should help.
    Reputation: NEstinkyrider's Avatar
    loosen the spring retainer so that the spring moves freely and you can compress the shock without having to compress the spring. that's what i had to do.
    Thanks, I tried doing the spring think but I forgot I had pro pedal on so it is pushing the piston back even with the spring loose. I will try taking that off.
    PEace HaMies
