02 Monster T travel...- Mtbr.com
Results 1 to 14 of 14
    Dirt Rag Extraordinaire
    Reputation: m0ngy's Avatar
    Dec 2005
    Hi
    Can someone please give me a difinitive answer on how much travel my 02 Monster T's (black ano lowers w/red decals) should have?
    The rep reckons 175mm, or 6.75 inches, but I find that hard to believe. I can't get more than 5 inches out of them. I've got the recommended oil, 380ml, and one heavy spring and one medium spring installed.
    "You go up the hill, you go down the hill."
    Chillin the Most
    I believe the 02 and earlier Monsters had 178mm (7") of travel. 03 and later went to 8" and of course the 03 Super Monster had 12".
    Dec 2005
    i want MORE!!
    how do i get more travel out of 'em?? 5" just ain't enough...
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Are you sure that all oil was purged out before you added it?
    How much sag do you have?
    If you have the proper sag, then start taking out oil.
    Takw/agranofsalt
    Jan 2005
    how much do you weigh? Maybe you need lighter springs. I weigh about 200 and bottomed out my monsters about once every three-five rides with the stock springs.
    edit - FYI: 175 millimeter = 6.889 763 78 inch
    Dec 2005
    you wouldn't FARKEN BELIEVE IT!! I JUST FARKING THREADED OUT THE TOP CAP!! AAARRRGGHHH!!!! FFS!!!!!
    yeah, i weigh about the same 200lbs and get about an inch, maybe inch and a half sag.
    so, two medium spring ya reckon? i'll have to try it. with two heavy springs i was getting some serious deflection.
    just an fyi, if you've got red decals, it was an 01. 02's had black decals, i think there was a smal dif. in the damper
    Dec 2005
    hmmm, you sure?
    i thought the 01 was like silver/chrome with traditional looking 'bomber' red decals, whereas the 02 was black ano with the same red decals. it the 03 that was black ano with black/gothic decals... am i right?
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Here's an '02.
    It's all black with some text and graphics in white and grey. The decal says 2002
    TNC
    TNC is offline
    noMAD man
    Use the oil level method.
    Quote Originally Posted by Jayem
    I agree with Jayem. It sounds like you could have too much oil. I think the oil level measuring method is a much superior way of monitoring oil volume and performance. My '02 springs were a little too stiff for me. I went a step down and mixed one softer spring with one heavier spring for an ideal setup for my needs. You can mix an match springs to suit your needs. The oil level for an '02 Monster is 100mm.
    [email protected] NYC Freerider
    Reputation: Master_Jako's Avatar
    Quote Originally Posted by m0ngy
    hmmm, you sure?
    03 was polished aluminum witha large black/gray stickers wrapped around...there is a model date posted around the drop-outs on every zocchi fork...go by that.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    Quote Originally Posted by Master_Jako
    no don't do that, the stamp is almost always a year before (sometimes more) when the castings are actually made, not when they are available for sale to the public....
    Dec 2005
    yeah, the lil stamp on the lowers says '01'...
    well, i think they might be 01 then, as the guy before said his 02's had black decals. that being the case, how much travel should 01 Monster T's have?
    thanks again for the info
    Chillin the Most
    Travel is the same for 01 as the 02, 7" (178mm). The 03/04/05 Monsters went up 8" and 12lbs.
