new to me Overdrive 29 2- Mtbr.com
Results 1 to 13 of 13
    May 2020
    Hello everyone,
    I just wanted to share a few pictures of my recent acquisition. I picked up this very lightly used overdrive. I've done a few things to it. new pedals, saddle, grips, tires, front mud guard and brakes.
    I am really excited to take it to my local trails. It has been a while since I've had a bike to ride.
    May 2020
    After taking this bike out on my local trails the past 3 weeks in a row, Iíve noticed that my large chainring is pretty chewed up.
    I am contemplating converting this to a 1x drivetrain.
    Can anyone suggest any components to accomplish this?
    Reputation: Rockadile's Avatar
    Jun 2005
    Thereís a bunch of forum posts (and probably YouTube videos) on conversions. What crank is on it now? Is it 2x or 3x?
    May 2020
    It currently has a 2x crank on it. FSA Comet crankset. I don't know if I want to replace the entire set. Or just find a new chainring.
    Jun 2005
    Basically all you should need is a new chainring and shorter chainring bolts. You should get a narrow-wide chainring in the proper size for your crankset. This link states your Bolt Circle Diameter (BCD) as 96. I am not sure if that is your exct crankset but, if not, you'll need to find your BCD.
    I also found the following video which appears to apply to your exact situation. Good luck!
    https://youtu.be/EicZPMxqmak
    May 2020
    Thank you for helping with the research.
    I would really like to try out an oval chainring. I'm going to see what I can find.
    May 2020
    I actually called Jenson yesterday for a little bit of help finding an oval chainring that I could mount on my FSA Crankset. There are non available that are compatible with the spider, or the direct mount pattern on this crankset.
    So to be able to get an oval ring, I would actually have to replace my crankset. The guy at Jenson was also telling me that I would have to replace my BB as well.
    It doesn't seem right that my existing BB wouldn't be compatible with a different crank.
    Either way, I am just going to keep running my current setup and then eventually changeover to a 1x12 with an oval chainring. I know people will probably say that this bike isn't worth all that $ in upgrades. But to replace this bike would cost a lot more money.
    Jun 2005
    Call Wolftooth Components. They have some elliptical 96 BCD chainrings listed on their site.
    May 2020
    All of their 96 BCD elliptical rings are for shimano. The Shimano Cranks have a rectangular bolt pattern. whereas the FSA spider a square pattern.
    The chainrings aren't in terrible condition. I think I was mainly looking for an excuse to buy new parts again.
    May 2020
    I have found that absoluteBLACK makes oval chainrings for direct mount FSA/Cannondale cranks. I wasn't aware that Cannondale and FSA used the same direct mount pattern.
    I've ordered a 30T oval from absoluteBLACK. As well as the SRAM NX/GX Eagle 11-50t Groupset from Worldwide cyclery.
    There are some really steep sections of the trails I ride that I can't even consider trying to pedal up with my current setup.(lowest gear being 26t chainring x 36t cog. Hopefully after the upgrade I won't have too much trouble at all. I can always swap the chainring for something smaller if needed.
    May 2020
    Still waiting for parts to show up. It is taking 8+ days for USPS to get from lancaster pa. To Buffalo ny...
    The package was in Buffalo on Tuesday. Then for some reason it went to queens, and then meandered its way back to this corner of the state
    May 2020
    Received all of my parts this Monday. Installed them and am waiting to take the bike out this weekend.
    May 2020
    Took it for a ride this morning. Iím really enjoying the new drivetrain. The big 50t sprocket really helps me climb the steep sections. Some of which I always had to hike. The oval ring is taking some getting used to.
    Attached Thumbnails Attached Thumbnails new to me Overdrive 29 2-6b02e3e1-c76c-4bf7-9e48-774e19d6197e.jpeg
  1. Replies: 4
    Last Post: 05-31-2013, 06:49 PM
  2. 2011 reign 2 overdrive or overdrive 2?
    By chef7734 in forum Giant
    Last Post: 01-12-2013, 11:12 AM
  3. 2012 Anthem X 29 Headset for Overdrive 2
    By dynamic161 in forum Giant
    Last Post: 05-15-2012, 01:57 AM
  4. Specialized HardRock sport 29 vs. Diamondback Overdrive sport 29
    By Tnadeau07 in forum Bike and Frame discussion
    Last Post: 04-03-2012, 03:11 PM
  5. Diamondback Overdrive 29'er - Anyone Jumping this Bike?
    By cpwalters83 in forum 29er Bikes
    Last Post: 08-12-2011, 09:17 AM
Members who have read this thread: 24
