Results 1 to 35 of 35
    Reputation: crankpuller's Avatar
    Troy shock upgrades- talk to me.
    I am looking for feedback on anything but the stock rock shox that came on my 2017 troy.
    It is tired and notchy.
    Leaning towards coil but open to hear what others have tried.
    Sent from my Nexus 6P using Tapatalk
    Oct 2016
    I am curious the coil shock performance. I dont like air shocks bec the reliability isssues.
    I can highly recommend the cane creek inline coil. I picked one up a few months ago and have been really impressed. I use my Troy for everything from XC to lift assist downhill and this shocks rocks. Makes the bikes feel super capable and the coil just has great feel. I am still getting it dialed in but I canít recommend it enough. I almost went with the DVO topaz air shock, it gets great reviews too. But the coil shock is a game changer in my opinion.
    Jan 2016
    Elevensix?
    Iíd be interested in hearing anyone who ran the 200 x 57 (or 55 custom) and how that affects the ride characteristics.
    Quote Originally Posted by CharlieDog View Post
    Thanks- after weeks of reading I have decided on the Cane Creek inline coil.
    Has anyone gone with the 57mm stroke to squeeze out a bit more travel?
    If so any regrets?
    Sent from my Pixel 2 XL using Tapatalk
    Feb 2018
    Quote Originally Posted by crankpuller View Post
    If so any regrets?
    I would personally avoid a 57mm stroke shock... I made a "dummy" shock out of aluminium and drilled holes in it simulating 57mm and 51mm stroke lenghts. In the "slack" chip setting the seat stay will hit the seat post tube before it is compressed, in the "steep" chip setting the clearance is minimal(around 2mm). Just a little to close for comfort in my opinion. I was hoping to run a 57mm stroke shock myself.
    Quote Originally Posted by fltmech09 View Post
    Thanks. Just ordered it from Cane Creek. They responded quickly when I inquired about the hardware required and were also the cheapest I could find online.
    I will post some pics once I get it setup
    Feb 2018
    Ride report is a must once you have a chance to take it out! The DBIL coil is very high on my want list!
    Got it mounted today and went for a spin around the block- can't do a real ride report until the spring but initial impressions are that it is really plush -
    May 2014
    Upgraded the monarch on my 2017 Troy Carbon to a 2017 float x2. It's a bit heavier than the monarch, but its amazing!
    I purchased a Monarch Plus in L/L tune. I find it spikey (I think), something is not right. The RT3 seems to be tuned better IMO.
    My previous bike was an Enduro with a Monarch Plus tuned for the Enduro, and I had the same feeling about it on that bike. Not sure what it is about the Plus.
    Two rides in on the cc inline coil and I can confidently say that this is the most noticable upgrade you can do to the bike. Biggest improvement is the washboard decents. The old monarch couldn't handle them. The inline coil flattened them. I was amazed how much more speed I was able to descend with due to being controlled vs rattled.
    I almost always have kept the climb switch off on this bike - it is unnecessary IMO. The climb switch on this shock keeps things active but muted and isn't a full lockout - traction everywhere. Either way I probably will not use the climb switch.
    Shock setup is the stock tune with 4 turns of preload. 400lb vault spring. 167 lb trail rider kitted up.
    Overall I am extremely impressed.
    Where did you start, and end up with the damper settings? I haven't seen any base/recommended tune for the Troy.
    Quote Originally Posted by coolatt View Post
    Kept the stock settings from cane creek
    2 hsc
    7 lsc
    2 hsr
    10 lsr
    Added 4 turns of preload in a 400lb spring.
    Been meaning to tweak it to give a bit more mid travel support but haven't yet.
    Aug 2018
    2 hsc
    7 lsc
    2 hsr
    10 lsr
    Just did the same, DB IL Coil 200x50. Came form a DPX2, which was quite good. This is undoubtedly a bike changer. Everything is better, climbing and descending.
    After a few testing sessions, here's where I'm at. I'm 150 lbs w/gear.
    Valt #450 spring, 1 turn
    HSC: 3.5 cw
    LSC: 10 cw
    HSR: 3 cw
    LSR: 13 cw
    I like a bit more platform, and this delivers.
    I finally received my CC DBCoil IL 200x50 with 450lbs spring yesterday. I selected the spring after using the CC spring selection tool.
    I have not changed any of the CC tuning but wanted to evaluate the sag. Unsagged I measure 200mm which is fine. However whether I have 0 or 4 preload turn I only get 15-20mm sag. Which is far from 28-32%. Am I doing something wrong or did I misunderstood something to measure the sag?
    Reputation: Dogboy's Avatar
    Quote Originally Posted by Evil Sylvain View Post
    That 28-32% should equal 14.25-16.32mm of sag.
    Quote Originally Posted by Dogboy View Post
    Thanks for the help. I have searched a bit more to find the following.
    https://www.fanatikbike.com/blogs/en...suspension-sag
    Dec 2012
    For those using the DB Coil IL, what mounting hardware is needed for the Troy? And excuse the dumb question, but I assume if you're between two springs you would opt for the lighter weight spring and then add preload is that correct? Is there any reason to go for the more firm spring?
    Quote Originally Posted by Tronner View Post
    I think stiffer is better. The coil doesn't ramp up like the air spring and I feels moves deep into it's travel very easily. Having said that I haven't tried a stiffer spring yet.
    Rider 180lb
    Spring 550lb
    Aug 2018
    42mm x 8mm upper
    9mm x 8mm lower
    I'd highly suggest the offset bushing in the lower, and a needle in the top. I got the offset bushing, going to order the needle bearing asap.
    Spring weight, I'd say it depends. I'd go with the stiffer rate, and run as little preload as possible, and get a stiffer platform.
    Dec 2012
    Rider 180lb
    Spring 550lb
    Thanks! Sounds like maybe 500lbs is the way to go for me. I am probably 175 with a full backpack and 165 with just a water bottle.
    Dec 2012
    Interesting, so are the offset bushing and needle bearing things you order right from them, and what do they do for you?
    Aug 2018
    Offset bushings: https://www.offsetbushings.com
    Needle Bearings: https://www.enduroforkseals.com/prod...mm-thru-bolts/
    The offset bushings are like the "flipchip," they add a level of adjustability to head angle and BB drop. I added one to the lower (much like the new Devinci models have relocated their flipchip there) to slack out 0.5, and drop the BB about 5mm. I have a 160 fork, so that helped get my BB back to where it should be, and give me a HA of about 66*.
    The needle bearings are used in place of traditional bushings which is what you'd normally get. The bearings are crazy smooth, and provide much less resistance to movement inside the shaft. Their effect is smoothing out trail chatter further and increasing sensitivity, all for just a little more than regular bushings.
    Dec 2012
    Quote Originally Posted by abacall View Post
    Got it. Thanks for the info! Last question, so for the 42X8mm replacement do you do the 41.15 or 43.74 needle bearing?
    Feb 2018
    Youíll want the 41.15 needle bearing kit. I used that and left the factory bushing at the bottom. Made a huge performance difference with the factory monarch shock!
    Dec 2012
    Thanks!!
    Jul 2017
    So, needle bearings... is it worth running them top and bottom?
    I've already got a 160 fork - and I already pedal strike a TON - I'm afraid that running any more lower bottom bracket is gonna be problematic?
    Or, just do it, go more slack cause I'll love my bike all the more and run a needle bearing and an offset?
    Oh, and if so on the offset - I hear rumors they last like 4 rides - any feedback to that end?
    Aug 2018
    Needle bearings are different from offset bushings. Offset bushings will slack out the HA about 0.5* and drop the bb about 7mm.
    I'm running a 160mm fork, and the offset bushing on the bottom. That gets me 66* HA, and about original BB drop.
    Running the offsets top and bottom will get you to about 65.5* and 5mm lower than original (which is already really low). I've run the bike on some seriously steep and loose stuff, and the 66* HA feels spot on balanced between tackling that and everyday trails.
    I still strike often, and I have a set of 170mm cranks ready to pop on here soon to alleviate the issue.
    Honestly, dropping the BB more is going to really annoy you if you're already bothered by strikes. You can always run 165mm cranks, but those have always felt weird to me. 170mm are fine (to me).
    As far as longevity, I've had no issues with mine. It's been about 500 hard ass miles.
    Oct 2014
    Hello i have an stock monarch rt3 shock on the 2017 carbon model. Planning to christmas gift my troy since the back seems very bouncy, can't get past mid travel most of times and in high speed technical sections the rear feels like falling apart.
    Two hard questions, db air IL or db coil IL. I do not jump high or drop a lot, just 2 feet max. I do like to climb a lot and sometimes do a 5 6 hours ride mixed road and mountain. I dont want to lose climb capabilities please help me! What would you recommend?
    Either I buy the coil or air shock do I need new hardware? I heard that I can mount the air shock with the stock hardware I have idk the coil one. 42 and 9 x8 right? No angle bearing since im ok with the geo. I live in southamerica and would like to order everything I need, mailed cane creek I got the size I need
    Ty a lot in advance.
    So I've had the DB Inline Coil for about 20 hours or riding. All the terrain I ride is extremely rock and rooty North Nan trails, barely any smooth parts.
    I've found that the shock has improved climbing climbing immensely. It feels that it stays higher in its travel for better climbing position and has superior traction, all without the climb switch enaged.
    Descending is a different story, I cannot get a smooth feel from it. It feels a bit harsh overall like it's either rebounding too fast or to slow at the same time. I've played with the dials based around the default base tune and watched the Vorsprung Tuesday Tune videos. Descending, I prefer the of-the-shelf L/L Monarch Plus I have. It might just come down to the progressive nature of the air spring is better suited to this bike.
    That's my take so far
    HSC 2
    LSC 4
    HSR 3
    LSR 6
    Quote Originally Posted by Geeezas View Post
    I purchased directly from cane Creek. They're quick to respond to inquiries and can ensure the proper hardware.
    HSC 2
    LSC 4
    HSR 3
    LSR 6
    Too much preload or wrong spring?
    Maybe, or the air spring is just better for me. I started with a 550lb spring and could bottom it failry easily, so I upped it to a 571 Ohlins coil.
    Oct 2014
    Air all the way
    Air worked for me. Did some research alltough I recognize the advantages of coil I am former XC rider and I like to pedal hard a lot, with coil some climbing performance is given, specially when CS off.
    This upgrade was night and day vs the stock monarch debonair rt3, the rockshox was with many bands I guess that was the reason I hardly used half of the travel.
    With CC I use the ammount of travel I want to use and leaving some space for big hits, tons of traction in rough terrain and planted, even in fast tech sections. Can't ask for more for a trail/am bike but just keep improving my skills. So happy!! My downhill speed got inmediately faster, stock setup worked for me, did some small tweak on the 4 adjustments towards the climbing performance that helped to give more support on g-outs and bouncy sections. Improved a lot with that.
    Ended up buying a hardtail for training and long rides, the troy will be only for mountain hard rides.
  1. Shock spacer grinding against shock on 2016 Troy Carbon
    By mdgentile in forum Shocks and Suspension
    Last Post: 07-14-2017, 04:57 PM
  2. Replies: 0
    Last Post: 07-14-2017, 10:13 AM
  3. Upgrades to the Troy
    By CDC in forum Devinci
    Last Post: 12-09-2015, 05:58 AM
  4. Let's talk Guardian component upgrades..
    By comphynum in forum Airborne
    Last Post: 06-20-2013, 10:05 AM
  5. upgrades, upgrades.... that is the question?
    By guyneutron in forum Specialized
    Last Post: 07-28-2011, 01:52 PM
Members who have read this thread: 83
