new 2016 Troy Devinci and fox 36 float 26"- Mtbr.com
    Hey guys, trying to figure out what to do here. I have a 2015 float 36 160mm 26" fork that seems it can fit a 650b wheel with big knobs. Wondering if anyone has used the float 26" 160mm fork with a 650b frame. Let me know.
    Yeet so hard
    Reputation: tims5377's Avatar
    Oct 2010
    Is the axle to crown and offset the same as the recommended fork?
    If so, you probably don't have a problem. If not, It will change your ride characteristics significantly (steepening all the angles, lowering BB).
    The fork is a year old. Why not sell it and recoup the majority of what you spend? I know I wouldn't be buying a new frame and then cobbling together the rest of my componentry.
    Guerrilla Gravity BAMF
    Smash
    I am trying to sell it but if it doesn't happen by the time I get the frame I might have to use it. Ideally I want a dvo diamond.
    Sent from my SM-G925V using Tapatalk
    Throw a 10mm spacer under the headset. It seemed to work for Specialized
  1. 2016 Devinci Troy
    By marathon dave in forum Devinci
    Last Post: 12-12-2019, 06:21 PM
  2. devinci troy?
    By RosedaleReaper in forum Devinci
    Last Post: 03-14-2016, 05:55 AM
  3. Devinci Troy RC or Stumpjumper FSR
    By CDC in forum Devinci
    Last Post: 07-14-2015, 10:08 PM
  4. Replies: 13
    Last Post: 01-11-2015, 11:40 PM
  5. Devinci Troy XP $2400
    By tl1 in forum Devinci
    Last Post: 09-06-2014, 10:55 AM
