Dropped a hex wrench inside the frame- Mtbr.com
Results 1 to 6 of 6
    Well this is great. When installing the cable housing internally on my Troy, I used a small hex wrench to guide and pull the housing out of the holes of the frame. It fell in. How do I get it out? Can I take the cranks off and access the inside of the frame without any special tools?
    Reputation: mfa81's Avatar
    seems like the troy has a press fit BB, I'd try first to remove the fork and try to get the wrench out through the head tube, seems easier than through the BB, not if your BB doesn't have the sleeves going side to side, them you might be able to get it out just removing the cranks... but still I'd try headtube first
    Ah, I didn't think of removing the fork. Good idea. Thanks.
    Quote Originally Posted by coolatt View Post
    Unfortunately there is no opening from the top or down tube to the headtube. Looks like I have to go in through the BB.
    Sep 2016
    Maybe a strong magnet would grab that hex key? Not sure if you'd ever get it back out of the cable port but might be worth a try.
    Phew. I managed to shake it out the seat tube.
  1. Bondhus Hex Pro hex keys
    By watermonkey in forum Tooltime
    Last Post: 01-22-2018, 03:21 PM
  2. Hex wrench question
    By JerB in forum Tooltime
    Last Post: 06-06-2014, 07:06 PM
  3. Small Hex Wrench problems
    By fetad in forum Tooltime
    Last Post: 03-30-2014, 06:07 AM
  4. Harbor Freight Hex wrench set
    By ericepark in forum Tooltime
    Last Post: 01-09-2012, 11:19 PM
  5. Replies: 1
    Last Post: 06-26-2011, 06:12 AM
