django black hose with frame?- Mtbr.com
    New frame came with 4 foot long black hose. Any idea what it's for?
    Reputation: Dogboy's Avatar
    Rattle-proofing internal cables. There should be enough for two of the three cables which usually does the trick.
    Quote Originally Posted by Dogboy View Post
    Thank you! Just gotta figure out best way to funnel housing AND black hose inside. Internal routing is fun (not).
    Quote Originally Posted by danK View Post
    The easiest way is going back to front. So once you've routed the hose/cable into to the lower hole in the downtube and it is popping out of the upper hole, go ahead and slide the foam tubing over it as you feed it the rest of the way - so you're pushing the hose/cable and foam tubing against one another. You can pull the hose/cable back into the frame and feed the foam tubing down into the frame. Make sense?
  1. 2017 Devinci Django 29er
    By Velorangutan in forum Devinci
    Last Post: 08-06-2019, 01:28 PM
  2. Django 29 owners. what size frame?
    By 65mtn in forum Devinci
    Last Post: 06-22-2017, 09:27 PM
  3. Devinci Django 29
    By Velorangutan in forum 29er Bikes
    Last Post: 06-18-2017, 10:23 PM
  4. Devinci django?
    By spoker247 in forum Devinci
    Last Post: 11-10-2016, 01:19 PM
  5. Hydraulic hose is hose is hose?
    By PoorBehavior in forum Brake Time
    Last Post: 03-24-2011, 07:13 PM
