Devinci Atlas Carbon?- Mtbr.com
Results 1 to 9 of 9
    Any of you guys have seat time on one of the new Devinci Atlas Carbon 29ers? I am very interested in one and canít find many review on them. I have ridden and owned a few similar bikes but never one with similar geo to it. From the geo numbers the head angle and seat tube seem steep, wheelbase short and when the adjustable geometry chip is placed in the low position the BB height is super low(12.87in). I feel like the bike would ride best in the high geo position with an angle set to reduce the head angle by -1 to -1.5 degrees.
    Any input from you guys?
    LO ST SA HA TT REACH CS WB BBH SOH HT
    cm deg deg mm cm mm mm mm mm mm mm
    S 46.0 72.2 70.6 590 38.5 430 1067 327 727 110 619
    M 49.0 72.2 70.6 610 40.3 430 1087 327 741 115 624
    L 52.0 72.2 70.6 633 42.6 430 1110 327 757 115 624
    HI
    ST SA HA TT REACH CS WB BBH SOH HT STACK
    S 46.0 72.9 71.3 588 39.2 428 1066 333 733 110 615
    M 49.0 72.9 71.3 608 41.0 428 1086 333 747 115 620
    L 52.0 72.9 71.3 631 43.3 428 1109 333 763 115 620
    Have you read this thread? http://forums.mtbr.com/29er-bikes/de...on-842785.html
    Also, the Atlas requires an integrated headset so you won't be able to use an Angleset.
    Jun 2013
    Quote Originally Posted by 12snap View Post
    Why is that an issue?
    Quote Originally Posted by bprice2 View Post
    An integrated headset uses bearings that seat directly into the frame. There are no cups to press in or install. The Angleset is not available to fit frames that use that headset style.
    If you want to use an Angleset, the frame needs to either use a headset with external cups, zero-stack cups or a combination. https://www.canecreek.com/products/headsets/angleset
    Quote Originally Posted by sb1616ne View Post
    ...... From the geo numbers the head angle and seat tube seem steep, wheelbase short and when the adjustable geometry chip is placed in the low position the BB height is super low(12.87in). I feel like the bike would ride best in the high geo position with an angle set to reduce the head angle by -1 to -1.5 degrees.
    The OP doesn't like the geo and wants to use an Angleset.
    Jun 2013
    Apparently reading comprehension isn't my strong suit.
    We've all been there!
    Jan 2013
    hehe I understood the OP the same way as you did, so you're not the only one
    Old and Crusty
    So I bought this bike in October and have been having perma-grin ever since. I had never ridden a 29er previously and had heard bad reviews of their sluggishness. Not so on this ride, nothing but awesomeness. This bike truly climbs better and allows me to glide over stuff at my nearby park that I always had trouble clearing. Never had a bike like this - one review said "I forgot I was on a 29er" - done that!! This bike is definitely worth every penny in my opinion, loving it!!
    JB
  1. Devinci Atlas Carbon
    By Billy Davis in forum 29er Bikes
    Last Post: 02-05-2019, 10:42 AM
  2. Replies: 14
    Last Post: 11-10-2013, 02:24 PM
  3. Replies: 0
    Last Post: 10-18-2013, 11:56 AM
  4. Replies: 1
    Last Post: 05-02-2013, 05:44 AM
  5. 2013 Devinci Atlas carbon 29er
    By jhardeman in forum 29er Bikes
    Last Post: 02-18-2013, 12:03 PM
