Atlas 1X Problems....
Printable View
  • 08-12-2016
    Z-Man
    Hey guys,
    Is anyone having trouble with their 1X on an Atlas? It immediately shifts off the cog in the rear if I backpedal when in the 42. It's a first gen aluminum Atlas with new Shimano 11 speed cog, XT der, new shimano chain, and race face cinch crank with a round 30t. The cain line looks pretty bad and have been trying different ring combos up front but no luck yet. Any ideas? Anyone run a similar combo that works?
    Thanks, R
  • 08-12-2016
    gt7152b
    That's a problem with most 1X drivetrains. I've had better luck with a Wolf Tooth NW chainring that is spaced appropriately for the Atlas Carbon GXP bottom bracket. Not sure if the Al Atlas has the same BB. It was worse when the drivetrain was new but after break in I can get a full revolution back pedaling without the chain jumping down. I also never had this problem with my 36T cog on my old cassette. The bigger you go back there the more extreme the angles.
  • 08-14-2016
    SikeMo
    I've got a Garbaruk RF Cinch oval ring paired with a Hope 10-44 cassette and have no backpedaling issues and a near perfect chain line. They're probably the only manufacturer making rings with a chain line designed for older, non-boost bikes.
    http://garbaruk.com/single-oval/oval...ss-mount.html/
