Anybody running needle bearings on their shock?- Mtbr.com
    Looking for any experience with needle bearings on Devincis, specifically a Spartan. Considering it for the high rotation pivot. Did it on my last bike & it was a good experience, but I know some suspension designs are harder on them then others.
    Sent from my Nexus 5X using Tapatalk
    Reputation: Dogboy's Avatar
    I wouldn't expect much of a difference on the Spartan considering neither pivot rotates much at the shock mount. The layout of the suspension pretty much drives the rear shock pivot (higher rotation of the two) directly forward. I could see the advantage on some designs, just not the Spartan so much.
    Those thoughts had crossed my mind, as had the fact that the reducer is so long & so direct driven that it may be very hard to keep it from bending/smashing the needles. Found one guy who had that exact problem on a Troy. But it'd still be good to hear from someone who's actually done it.
    Reputation: In2falling's Avatar
    Jan 2005
    Nothing moves on the Spartan, look at the first part of this vid. Also down side of needle bearings is you might introduce some flex/play. It would be a waste money/time on your Spartan.
    https://www.youtube.com/watch?v=MoIOrsQ7WVI
    On Devincis vertically mount shock bikes (Troy, Marshall ect..) putting one on the top mount should work great (only need one on top, bottom does not move).
    I have one on top mount on my older Atlas and it made a huge difference, had to add 3 clicks of rebound after installing. I could feel less stiction and improved overall smoothness.
  1. RWC shock eye needle bearings on modern Trannys
    By cunningstunts in forum Transition Bikes
    Last Post: 06-07-2016, 06:02 AM
  2. Question about shock needle roller bearings...
    By tkm16 in forum Shocks and Suspension
    Last Post: 04-05-2015, 07:44 AM
  3. Shock needle bearings on a Stumpy?
    By timmaayyy in forum Specialized
    Last Post: 06-20-2014, 08:05 PM
  4. RWC shock eye needle bearings for 2011 RZ 120
    By FLMike in forum Cannondale
    Last Post: 01-08-2013, 01:44 PM
  5. Question about shock needle bearings for my Prophet
    By euskafreez in forum Cannondale
    Last Post: 09-18-2012, 08:13 PM
