Results 1 to 2 of 2
    AngleSet and/or 140mm fork
    Currently have 130mm Fox 34 Factory and regular Cane Creek headset.
    Thinking of putting Django 29er back in high mode to steepen seat angle. I find the low setting not the best climber even at 25% sag due to the soft trail tune. But I like the 68d HTA in low. I notice the difference between high and low even though it's just a claimed half degree.
    A 140mm air shaft is about $35. Probably need the $15 tool to prevent rounding/stripping of air cap (uh, like my other Fox fork mishap). That would shorten reach, raise bb a little, slack front end .5 degrees and slack seat angle .5 degrees if my armchair calculations are correct. But the air shaft has the new EVOL and reports say it's a big improvement over my 2017 air shaft.
    The AngleSet retails for about $160 but there are holiday sales now. I'd get the -1 which would let me have a 75 STA and 67.5 HTA with a 130mm fork. Plus pay shop labor of $10.
    I like the bb height in both settings, FWIW.
    Anyone do either or both? What's your input if wanting to keep seat angle in the high 75 degree mode but NOT wanting the 68.5 HTA.
    Reputation: LyNx's Avatar
    There's only one option if you wish the STA to remain the same, angleset, that's it. Alternatively, you could push the saddle further forward on the rails if you currently run it centered, that would effectively give you a steeper STA and an improved/better air spring is always good
  1. Replies: 6
    Last Post: 10-22-2018, 03:42 PM
  2. Tallboy LTc 140mm or 150mm Pike, angleset ?
    By M320 in forum Santa Cruz
    Last Post: 03-09-2015, 02:10 PM
  3. Replies: 4
    Last Post: 01-28-2015, 12:16 PM
  4. White Brother 140mm Loop 29er vs Manitou TOWER PRO 140MM 29er
    By hang10jeff in forum Shocks and Suspension
    Last Post: 09-13-2013, 11:32 PM
  5. Replies: 8
    Last Post: 05-06-2013, 05:37 PM
Members who have read this thread: 29
© Copyright 2018 VerticalScope Inc. All rights reserved.
