2016 Troy Cranks- Mtbr.com
Results 1 to 2 of 2
    May 2014
    2016 Troy Cranks
    I need some crowdsourcing help. I have a custom 2016 Troy Carbon, running xx1, with 31mm innder dm carbon hoops. I'm running hds now, but probably will switch to dhf/dhr 2.6s this fall.
    The bike just past the 1yr mark, and I the next sl crank arm fractured and its not covered under rf warranty.
    bike shop recommends xt cranks, or xtr. I wasn't sure about xt or xtrs due to boost rear and chainline. I also was thinking about sixcs - since they have a boost version. Or maybe, 3 mm doesn't matter that much.
    I like the Troy light, so weight savings are valued. but, I have the Troy slacked out with a 160mm fork and 1 offset bushing. So, I do have the occasional pedal strike.
    Anyway, suggestions are welcomed. thanks!
    For other's reference:
    I have an identical setup of a 160mm fork and 1 offset bushing. I have 170mm Race Face Turbine cinch cranks. Don't get those, they creak endlessly even if you completely disassemble and grease everything. I do hit the crank ends on stuff and wouldn't run longer than 170mm. The cranks are non-boost but the chainline is good.
  1. 2016 Devinci Troy
    By marathon dave in forum Devinci
    Last Post: 12-12-2019, 06:21 PM
  2. What cranks for 2016 troy, need help!
    By jmallory in forum Devinci
    Last Post: 06-07-2016, 05:46 PM
  3. 2015 vs 2016 Troy carbon
    By marcus_dukakis in forum Devinci
    Last Post: 11-23-2015, 02:07 PM
  4. new 2016 Troy Devinci and fox 36 float 26"
    Last Post: 08-28-2015, 11:49 AM
  5. Cranks Cranks Cranks..BB30?
    By 29or6to4 in forum Singlespeed
    Last Post: 05-26-2012, 02:13 PM
