What 1x gearing is everyone running for cx racing?- Mtbr.com
Results 1 to 31 of 31
    I like turtles
    Reputation: TiGeo's Avatar
    I'm on a 42 with a 11-32.
    Sent from my SM-G950U using Tapatalk
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Sep 2017
    I'm on a 40 with a 11-42.
    I like turtles
    ^^^Nice. I run a 11-40 with the 42 when I convert my CruX to gravel mode. Question, do you ever have any issues with back-pedaling with that cassette and the chain jumping off the cassette to the outside (when you are going fast in your smaller cogs)? This happens to me from time to time due to the heft of the XT 11-40 and the inertia it generates. Basically, when I back-pedal at the speed (even just stop pedaling abruptly) the cassette continues to rotate a bit b/c it's so heavy/takes time to slow down and the chain slackens briefly. Thinking I just need a much lighter cassette! No issues with the 11-32.
    Sep 2017
    Never had any issues with the chain jumping off (knocking on wood). However, now that you mention it, I have noticed the cassette continuing to rotate when I backpedal.
    This is going to be my first cross season and have been using my bike on races such as the Belgian Waffle Ride. I'm actually trying to see if I can gain more top end speed while not losing my climbing gear because I find myself spinning out when trying to keep up downhill on the road. I've been staring at the gear calculators the past 2 days and it feels like I'm staring into an abyss.
    I'm running a 40t chainring and a11-32 cassette for cross, then switch out the 11-32 to an 11-40(and chain) for gravel.
    EXODUX Jeff
    Feb 2013
    I'm on a 39x11-32 (mid-pack cat1/2 masters 45+). Our courses are generally pretty rough and/or muddy, - good to have a fairly low gear.
    skidding is the signature of the novice; learn how to use your brakes.
    I'm on a 40 chainring and 11-32 cassette.
    Quote Originally Posted by TiGeo View Post
    I've had the cassette keep moving when I stop pedaling, but it's usually due to drag in the freehub body, not just that the cassette is heavy. What kind of hub is it?
    I run 42 x 11-36
    40 with an 11-32! I have a 42T chainring too, but rarely if ever do I feel a need to use it!
    Reputation: 7daysaweek's Avatar
    I have a 2x but never shift out of the big ring during races so 46 x 11-28 for me. Seems fine around here, especially early in the season when things are dry and fast.
    Nov 2006
    38 Oval CR, 11-28. CX Racing only.
    Reputation: Chad_M's Avatar
    Jul 2013
    Quote Originally Posted by 7daysaweek View Post
    You must be pretty strong to use that.
    Ridley CX, Stumpjumper Carbon HT, Surly Wednesday
    Quote Originally Posted by Chad_M View Post
    Just flat around here. Most of our cross courses don't have much in the way of hills.
    Reputation: Scott@GO-RIDE.com's Avatar
    I race in an all ages B class and usually run a 36 oval (also have a 38 oval) and an 11-32 cassette. I see lots of guys with bigger gearing, but I usually finish ahead of them and I've never run out of top end. I do race at about 5000' of altitude and often have multiple hills. I pass a lot of guys on the climbs who are barely turning the pedals at walking speed because they don't have a low enough gear.
    Can't keep track anymore - Giant, Santa Cruz, Pivot, Yeti, Norco, Salsa, Intense - if it rolls on dirt I like it
    Feb 2013
    If my carbon crank didn't have 130 spacing (38 is the smallest that will fit) I'd probably run a 36x11-32, on our typically rough or muddy courses I doubt I'd ever run out of top end. - I recently changed to an oval ring, the first couple of rides (and 1 race) I thought it was just marketing, but on the steepest hills climbing is noticeably easier, like at least 1 tooth smaller in front.
    Feb 2013
    I get to try 36x11-28; I just bought a used Blue carbon Norcross with that gearing. I'm going to try to stay with the 11-28, 28 should be low enough for racing, it's pretty close to as low as my 39x32.
    I like turtles
    After tonight's race, I'm going to a 38 with a 11-32....better to have lower gearing in my experience.... never max the gearing out with a 42/11-32 but would love to spin a faster cadence on some of the climbs.
    40t front x 11x32 rear for cx racing and cx season riding around/training. I put on a 11x36 cassette for road/gravel season.
    I was on a 42t front last year, always felt like I was using the same few large cogs on the rear in cx races. The 40 lets me use more of the cassette. Wouldn't mind trying a 38 for cx racing.
    And I might look at an 11x42 or something like that for the off season next year, mostly because then I could use a 42 or 44 on the front and get a bit bigger top gear for long road descents.
    I like turtles
    A 42 11-40 works great for gravel grinding.
    Aug 2014
    36t x 10-42t
    (Salsa Cutthroat)
    top end is almost identical, gear-inch wise (105.88 vs. 104.72) to a 40-11 setup
    just ride.
    I like turtles
    Installed my 38t ring...much better lower end. I think I may just go 11-36 for gravel with this ring. Same low end as I had with a 42 11-40 just lose a little on the top that I don't use much. Much lighter overall setup this way.
    TelemarkTumalo
    Reputation: telemarktumalo's Avatar
    Nice shop!
    "Dang! You got shocks, pegs. Lucky!
    Reputation: Pegleg81's Avatar
    Aug 2014
    Wolf Tooth 34 x 10-42. 34 front is really nice when you're on the second of back to back cx races. 38 x 11-36 for road. 52? x 11-36 if I want to do another flat crit. After chain coming off thrice in two muddy races, got a k-edge chain guide.
    '15 Spesh Epic World Cup
    '16 Spesh Crux
    '17 Spesh Epic HT
    Reputation: sissypants's Avatar
    Sep 2016
    42T oval WolfTooth cinch chainring up front, SRAM XG-1195 10-42T cassette in the back, and SRAM Rival derailleur paired to SRAM Force levers and brakes.
    I don't recollect ever using the 42T cog in the rear over 1200 miles.
    Rival shifting isn't very crisp and I get some ghost shifting issues when it gets at all dirty.
    Nov 2008
    I am running 42 x 11-36 on my crux.
    Reputation: bizango's Avatar
    Mar 2016
    36 x 11-28. The low end is good for most racing and I like the tighter spacing to better ensure I can find the right gear. I've never had an issue with not enough high end (for racing...for gravel riding it'd be nice to have a little more top end).
    Quote Originally Posted by bizango View Post
    I've been running that combo for the last 3 seasons. Same opinion, plenty of low end, plenty of top end with tight spacing.
    '15 Giant Anthem SX - '01 Schwinn Homegrown Comp - '12 Giant Defy 1 - '14 Kona Jake the Snake - '18 Rocky Mtn Altitude A30
    Jan 2018
    Nice shop! Nice bike!
    Jan 2018
    40 x 11-32 is a good overall setup.
    ejh
    ejh is offline
    "A" bike oval 38X11-34 "B" bike 36X13-29, never ran out it top end
    Depends how strong you are and riding style, but generally speaking, 38-42 in front and a 11-32 out back is a solid combo. I personally like Oval chainrings and I think I'm currently on a 42....or it could be a 40, both work well. Top end is rarely the issue and I think undergearing if you can is actually a good strategy so you don't kill yourself.
    There are some fast single speed guys who are not THAT much slower that the top geared guys, just sayin.
  1. Replies: 0
    Last Post: 04-14-2016, 07:20 AM
  2. running multiple bikes with different gearing
    By goodmojo in forum General Discussion
    Last Post: 06-06-2013, 03:50 AM
  3. What are you 1x9 guys running for gearing?
    By Crash Dummy in forum Ibis
    Last Post: 10-05-2012, 11:13 AM
  4. So what SS gearing are YOU running at the Lumberjack 100?
    By dmabraham in forum Endurance XC Racing
    Last Post: 06-27-2012, 11:30 AM
  5. Time for new Tires what is everyone Running?
    By Dr_Ryan in forum New Mexico
    Last Post: 04-11-2011, 10:17 PM
Members who have read this thread: 96
