Open tubular CX clinchers with latex tubes; vs tubular tires for cyclocross- Mtbr.com
Results 1 to 7 of 7
    What do you guys think about "open tubular" clinchers with latex tubes (for CX); vs tubulars. The Challenge versions have a very similar high TPI cotton casing (like the tubular versions). I can run fairly low pressures (on my Challenge Grifo "open tubular" clinchers) with the latex tubes, but since I weigh over 200#s, it is in the 20s not the teens. Either way, they ride very well, and I can't see going back to tubular for myself. Has anyone heard of any pros racing "open tubular" clinchers?
    Technology
    Attached Thumbnails Attached Thumbnails Open tubular CX clinchers with latex tubes; vs tubular tires for cyclocross-open_tubular_render.png
    Open tubular CX clinchers with latex tubes; vs tubular tires for cyclocross-tubular_render.png
    I've had a Limus bead pop off the rim under hard turning. Which is kind of a bummer.
    In my opinion, there is still no substitute for tubulars for racing cross.
    Wow- I have not heard of a properly seated tire's bead popping off the rim, that defeats the purpose for sure! Are there any other manufacturers making a similar cotton casing clincher, with better results in use?
    Jan 2014
    I've never heard of a tire coming off the rim in that manner either.
    I believe vittoria might do "open corsa" clinchers but maybe only for road. I personally have no experience with challenge's open tubulars but plenty of people like them combined with latex tubes (or other supple tires with latex tubes) and report good things. Supposedly the latex tube is supposed to be more resistant to pinch flats.
    I don't know any pros that aren't running tubulars though. I imagine some may try tubeless but I'm not sure there either. There are probably more cat 1/2 guys running tubeless than pro guys. Tubulars are still the most widely used and I don't see many clinchers/tubeless even in the elite races.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    clinchers with latex tubes pop tubes all the time
    my faaaaaast cx racer buds -all- prefer old-skool glue+sewups for the best seasonal results in CX and SSCX
    -clinchers work but use butyl tubes and they are heavy
    -latex tubes and clinchers are shown to just not last long at all, they fail at the middle of the rim and valve area (at least the ones they tried)
    -tubeless with sealant, always find a way to roll them off the rim on every course
    -tubulars and glue. works best all conditions, super strong wheel too
    Has anyone tried the Vittoria 320tpi cross clinchers?
    Cyclocross Categories Vittoria
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    As I read the Vittoria Specs as presented: 320 tpi for Tubulars, 150tpi for Clinchers.
    No 320tpi clinchers here.
    Eric
    If I don't make an attempt, how will I know if it will work?
    There is a great discussion going on in the forum at CX Magazine regarding tires (Tubular, Open Tubular, and Tubeless options): Best all around cyclocross tubular - Cyclocross Magazine
  1. Replies: 1
    Last Post: 03-08-2013, 04:17 AM
  2. Sealant in tubular tires?
    By Fakie1999 in forum Cyclocross
    Last Post: 09-30-2012, 06:45 PM
  3. Replies: 10
    Last Post: 12-02-2011, 06:44 PM
  4. 29ER TUBULAR tires and latex tubes
    By Litemike in forum 29er Bikes
    Last Post: 03-03-2011, 02:43 PM
  5. Tubular MTB Tires
    By richwolf in forum 29er Bikes
    Last Post: 02-10-2011, 07:19 PM
