Zion fork diameter- Mtbr.com
Results 1 to 3 of 3
    Sep 2004
    Zion fork diameter
    What is the diameter of the upper fork legs on a zion fork? Are they 28.6mm 31.8mm or something else. If someone could check this statistic and post the information I'd appreciate it.
    what do you mean upper fork leg?
    it is a rigid fork so i don't think there is an upper and lower.
    maybe someone else will correct me?
    i measured mine and it is 26mm in diameter, the legs that is.
    what you're talking about sounds more like a seat tube.
    Reputation: AtotheZ's Avatar
    Nov 2007
    This sounds like a stat that you could only get if you called Jenson
