Zion Build Questions...- Mtbr.com
Results 1 to 2 of 2
    Dec 2005
    I'm working on building up a 19" 660 SS and I have a couple questions...
    1. Will there be any clearance issues using the 2.1 Kenda Small Blocks? The rims are Sun MTX's if that makes any difference.
    2. I plan to run 175mm Eno crank arms and was wondering what spindle length I should use. I've read that Eno cranks dont always clear unless you use long enough spindles.
    Reputation: marks_bike's Avatar
    You should be fine with the tires. Pretty sure the small blocks run just a little thinner than 2.1. Plus with less aggressive tread you should have lots of clearance.
    Not sure about the cranks though. I would just go with a normal 113mm BB. --Mark
