XCL Links- Mtbr.com
Results 1 to 9 of 9
Thread: XCL Links
    Reputation: kevmortensen's Avatar
    XCL Links
    I was talking with a friend of mine at a local trailhead that also owns a chumba XCL, and we noticed that our shock monunts had different shaped links. It would appear that his has more leverage on the shock than mine. Then I came home and noticed that the ones that people have posted on this site also show a range of differences on the rear shock mount. Is one better or worse to have? Is the latest the best leverage rate to have on the XCL? am I missing out on a upgraded part on my 07 XCL?
    ALAN, please put my mind at ease.
    RIDE 'TILL YOU PUKE
    Older than I feel
    I think yours is the old spec that's shorter travel. I don't know if there's any other real difference.
    Work is the curse of the biking classes.
    no, mines the 5" version. . . . .
    it seems that the closer the pivot on the shock mount is to the upper pivot on the link the more leverage there is on the compression of the shock, so if themount on the new links are closer to the upper pivot as they appear to be, wouldn't there be more leverage on the shock, and a shorter shock stroke to achieve the same travel at the rear axel as well?
    RIDE 'TILL YOU PUKE
    BrassBalled DropbarNinja
    Reputation: mrpercussive's Avatar
    it's not all about how much leverage... it's about the leverage rate...
    Reputation: CHUMBAevo's Avatar
    Kev - what size is your XCL?
    Simple | Proven | Reliable
    http://chumbaracing.blogspot.com/
    Don't be a sheep
    Sep 2004
    They vary with frame size.
    "Do not touch the trim"
    Quote Originally Posted by CHUMBAevo
    It's a Small.
    RIDE 'TILL YOU PUKE
    Here's a pic of my friends 08 Small XCL... looks like the same one you got...
    Quote Originally Posted by mrpercussive
    Wow, well thats a simple explanation. . . .
    so smalls have this link and all others have the different link?
    I am going to guess that this is because the seat tube is longer on larger frames and you are keeping the shock position the same realtive to the top tube?
    I find this very intriguing. . . .
    RIDE 'TILL YOU PUKE
