XCL Frame angles with 130mm fork- Mtbr.com
Results 1 to 17 of 17
    I'm really stoked about the new XCL. Looks beefy enough to stand up to tech XC trail
    riding with an occasional drop or two. I'm not worried about the extra frame weight.
    I think its worth it in this case, it'll be flex free and durable. I was wondering about the
    geometry numbers, though. I see on Chumba's site it says 69 and 73 for the HA and SA.
    It didnt say what travel fork this was based on. Does anyone know what the actual
    numbers would be with a 130mm fork ?
    Made in China
    I think those numbers are based on the 06 frame and 130mm fox talas fork. I know people who put a 140mm Fox Talas on that frame and did not change the handling at all. Hope that helps.
    "Didn't your doctor tell you to stop smoking and drinking?" George Burns "Yes but they all died"
    Maybe ChumbaEVO could respond with something more definitive. I'm also wondering
    how the recent frame changes will affect the geometry, will it going to stay same as before...
    bbc
    bbc is offline
    Bueno!
    Reputation: bbc's Avatar
    The new XCLs are going to have the Rockshox Pike for the fork which is 140mm of travel. The XCL has 4.5 inches of actual travel. A lot of bikes that have 5 inches of travel only have about 3.5 inches of actual travel. The XCL rides like a 5 and 1/2 inch travel bike, so the new FOX TALAS or Rockshox Pike is a great choice.
    Well, if its the same geometry as the Motolite, that wouldn't work for me.
    I tried the ML, and on a very steep granny ring climb, I felt a little bit of lower
    back strain. The fork was a 130 and I had the seat height correct and the frame
    was a large, so I'm attributing that to the rather slack (71.75) SA at 130mm,
    which pushed me too far toward the rear for an ergonomic climbing position.
    Reputation: CHUMBAevo's Avatar
    Quote Originally Posted by le_buzz
    Yes, Duke777 is correct, its based off of the older Fox forks at 130mm. But yea, I'll measure the head angle with the new 140mm Fox forks and see what it is. I've spent good time on both set ups, and the handling is dialed on both set ups. As for travel, 07 XCLs have 5 inches of rear wheel travel.
    Simple | Proven | Reliable
    http://chumbaracing.blogspot.com/
    Quote Originally Posted by CHUMBAevo
    Cool, I'm looking forward to April. Looks to be one sweet ride.
    Measured the head angle with the 140 mm Fox fork, and it is still hovering right around 69.
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    10mm increase in fork Axle-Crown should equal approximately a .5 degree slackening in the seat-tube and head angles. And, raise the bottom bracket by .16 inches.
    Quote Originally Posted by dulyebr
    The 07 Talas should be the same AC height as the previous models, just with more travel.
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    Mar 2005
    I have a sneaking suspicion that the XCL will be reviewed in MBA very soon.
    But only because they were using one in that headset instructional pictorial, and I've noticed tha's how it starts.
    Dec 2005
    Sounds like it needs some Marzocchi stoke up front then, or else MBA might take a shining to it .
    MTBGremmie
    Reputation: jSatch's Avatar
    What is the AC height of a Talas?
    I have a Marzocchi fork and would like to compare.
    EDIT: My current fork is only a 120 mm, and I am worried about having too steep a headtube angle. Axle to Crown length is 499 mm. Cheers.
    Made in China
    found this off of the forum....
    CANNONDALE
    leftymax 140 spv : 510 mm
    leftyspeed DLR 110mm: 480mm
    superfatty 80mm: 478mm
    Fatty 50mm: 448mm
    FOX
    vanilla R 2005: 510 mm
    Talas RL 2004: 490 mm
    Talas RLC 2006: 503mm
    Talas RLC 2007: 511mm
    vanilla 2004 un peu moins de 500 mm
    Float 80mm : 451mm
    100mm : 471mm
    36 Talas(2006) en 150mm : 535mm
    en 110mm : 495mm
    36VAN RC2 (2006) en 160: 545mm
    40 (2006) : en 178mm : 546mm
    -------------- en 203mm : 571mm
    KOWA
    80 Cs (2006) en 100 mm: 470 mm
    MARZO
    Z1 130mm drop off QR20: 503mm (2001)
    Z1 FR SL (2003) 530 mm
    Z1 FR 130 (2005): 518mm
    Z1 FR 150 (2005): 538 mm
    Z1 MCR (2001)130: 510mm
    Z1 LIGHT ETA 150mm (2006): 538.5mm
    Z3 Flylight 100mm (2000): 500mm
    Z5 air en 100 (2001): 478 mm
    888 (2005) en 200mm, 605mm
    888 (2005) en 170mm, 575mm
    888 (2006) en 200mm: 579mm
    66 (2005) en 170mm, 595mm
    66 (2005) en 150mm, 575mm
    66 (2006) en 170mm: 555mm
    66 (2006) en 150mm: 535mm
    Marathon S millésime 2002 100mm -> 480 mm
    Marathon S 120mm (2005): 495mm
    Marathon XC 120mm 2005: 495mm
    MX Comp en 105mm: 478 mm
    MX Comp en 105mm (2006): 484.3mm
    MX Comp en 120 mm : 493 mm
    MX Comp en 120mm (2006): 499mm
    MX Comp en 85 mm : 458 mm
    MZ comp en 100 mm: 488 mm
    EXR PRO en 105 mm: 478 mm
    EXR PRO en 120 mm: 493 mm
    all mountain 110 498mm
    all mountain 130: 518 mm
    all mountain 150 (2005): 538 mm
    all mountain 150 (2006): 541.5mm
    DJ2 2004 = 500mm
    DJ en 100 mm (2005): 488 mm
    DIRT JUMPER (2006) en 100mm: 483.5mm
    shiver sc 120 mm : 510 mm
    shiver DC: 572mm
    Junior T 2003/2004/2005: 555mm
    Junior T 2001 = 540mm
    Monster en 200 mm: 595 mm
    MARZO 2007:
    Corsa WC 80mm:464mm (déport 44mm)
    Corsa WC 100mm: 474mm
    XC700 SL: 464-504mm (déport 34,5mm)
    XC600: 474mm
    XC500: 474mm
    Z1 RC2: 538mm
    Drop Off 3: 538mm
    AM SL 1: 511-551mm (déport 44.7mm)
    AM 2: 531mm
    AM 3: 531mm
    DJ 1: 483mm (déport 44,5mm)
    DJ 2: 483mm
    DJ 3: 483mm
    Dirt Jam Pro: 483mm
    66 SL 1 ATA: 525-565mm (déport 44mm)
    66 RC2X: 565mm
    66 RC2 ETA: 565mm
    888 WC: 584mm (déport43.5mm)
    888 SL ATA: 554-584mm
    888 RC2X VA:, 584mm
    888 RV: 584mm
    Super T RCV: 574mm
    MX Pro ETA: 508mm (déport 44,3mm)
    MX Pro ETA: 488mm
    MX Pro: 488mm
    MX Pro: 468mm
    MX Comp 1": 468mm
    MX Pro I.S.: 488mm
    MAVERICK
    Duc 32 : 517 mm
    ROCK SHOX
    pike: 517mm (deport 42mm)
    Lyrik en 160mm: 545mm +/- 5mm
    Domain en 180mm: 565mm +/- 5mm
    Totem en 180mm: 565mm +/- 5mm
    Reba 85mm: 458mm (déport 39mm)
    Reba WC en 85mm : 465mm
    Reba en 100 mm : 473 mm (déport 39mm)
    Reba WC en 100 mm : 480mm
    Reba 115mm: 488mm (déport 39mm)
    Reba 29" 100mm: 510mm (déport 39mm)
    Boxxer 04 (178mm de débattement), 555mm en position basse
    Boxxer 2005 race, team et world cup en 203mm : 570mm en position basse
    Psylo SL uturn : 510 mm
    Duke XC 80 mm 2004 : 460 mm
    Duke C (année inconnue) 80 mm de dbt : 440 mm
    Pilot en 100mm : 475mm
    SID RACE 80mm: 442mm
    SID SL 2001 80mm: 450mm
    SID 1998 63mm : 435mm
    Revelation 130mm (2006): 508mm (déport 39mm)
    Revelation 100mm (2006): 478mm (déport 39mm)
    PACE
    Distance RC 39 modèle 2005 en 100 mm: 470mm
    RC41 Fighter en 150mm 2006: 524mm
    MANITOU
    Axel Elite 100mm : 480mm
    Skareb Super TPC 100mm (modéle 2005): 475 mm
    Black Platinum (Reglage maximum):515mm
    black comp 2002: 475mm en debat 100mm
    Stance Flow:502/532mm
    Stance Kingpin: 540mm
    Stance Static 80mm: 460mm
    Stance Static 100mm: 480mm
    Dorado DH: 542.5mm
    Sherman Breakout Plus: 512/552mm
    Sherman Flick Plus: 492/532mm
    Sherman Firefly Plus: 492/532mm
    Sherman Jumper: 455mm
    Sherman Jumper 110mm : 480mm
    Sherman Slider Plus: 540mm
    Nixon Platinum/Super/Elite: 518mm
    Minute 1/2/3: 505mm
    Minute 3 (en 100mm): 470 mm
    Millenium: 505mm
    Splice 100 mm: 505mm
    Splice Elite 130mm : 525mm
    R7 (2006) en 100mm: 470mm
    SUNTOUR
    XCP-E en 100mm = 480mm
    XCP-DRL en 80mm: 460mm
    XC-50: 455mm
    xcp 75: 465mm
    ncx-d en 80 : 450 mm (2005)
    MAGURA
    Big Ego en 185 mm : 580 mm
    Thor en 150 mm : 535 mm
    Ronin en 110 mm : 483 mm
    Phaon en 125 mm : 504 mm
    Asgard en 100 mm : 476 mm
    Asgard en 80 mm : 456 mm
    Vidar en 80 mm : 456 mm
    Quake 115 double té: 525 mm
    FOURNALES
    Cobra XC: 451 à 454 mm
    SUNN
    Carving (1998): 510mm
    MTBGremmie
    Quote Originally Posted by duke777
    Perfect,
    Thanks!!
    ChumbaEVO, could you measure the SA on the new XCLs to see what it is, say with the
    fork at 130 ? I recently saw some pics on the TItus forum of the XCL and Motolite
    side by side, and it looked like the SA was the same or very close on both bikes; the
    Motolites is 71.75 at 130mm for the fork. I know its hard to tell exactly from a picture,
    but I was wondering if your measurement was maybe a tad off.
