XCL DHX Air problems.- Mtbr.com
Results 1 to 3 of 3
    Don't be a sheep
    Sep 2004
    I Completely purged the air from the shock last night per Chumbas recommendation and refilled the shock. Half way through my ride tonight I noticed the shock bobbing quite a bit, tried to dial in more Pro pedal but nothing helped. Stopped and checked the air and it appears I lost 100psi (of the 150psi I filled it with) from the Pro Pedal chamber and the main chamber gained 80 psi, is this possible? It's funny, I've been running a Manitou Swinger on my previous bike without a single problem for 2 1/2 years, I run a High Dollar Fox for two rides and it's already got problems. Oh and it appears to have fluid weeeping from the shaft seal, sweet.
    "Do not touch the trim"
    Older than I feel
    The leaky shaft seal is not unique to Chumbas. A friend had to send the DHX Air on his Ventana El Ciclon to Fox twice to get it to stop leaking. Another friend has one on another Ventana and hasn't had a problem.
    Reputation: hardway's Avatar
    The DHX A on my Evo wept oil. I was told it was normal. Your other problems don't sound normal. Talk to Allen or Fox or both.
