XCL with cable stops/brake line brazings on wrong sides of frame- Mtbr.com
Results 1 to 3 of 3
    customized
    Sep 2003
    Has anyone seen a frame with the derailleur cable stops on the left side of the frame and the rear brake line brazings on the right? I have a brand new XCL I am building with just this issue. I did a search and did not see anything.
    Honestly I put in a couple Jagwire Hydraulic adapters in to run the brake lines directly underneath the top tube as well as running the front derailleur cable/housing on the left side and the rear derailleur on the right side (with a long housing run) with pleasant results.
    I just put mine together and the brake was on the left and both derailleurs on the right.
    customized
    Sep 2003
    Alan emailed me from Chumba. This is an earlier model of the new design of XCL. That is good news.
